Question about Aquacal Super Quiet Electric Pool Heat Pump Sq156
What does LPS mean - Aquacal Super Quiet Electric Pool Heat Pump Sq156
I have a chevrolet cavaleer 1997 and the heater nor the ac work. The fuse box says inst lps isnt working correctly. What can i do. Also in the fuse box the rr dfog is not working either. Help me!
heater nor a/c work-does this mean the fan is not blowing-can you feel hot or cold air while set to hot or cold while driving-inst lps and rr dfog have you replaced the fuses-cheers Denny
Oct 30, 2013 | Cars & Trucks
LPS
Liters per Second.
Rod
US Parts Center
May 02, 2013 | Aquacal Super Quiet Electric Pool Heat...
I just recently bought a new turntable, and when it plays my LPs, the LPs sound somewhat slower than the original. Does the slowness have to do with the belt of the turntable? Is there anyway I can fi
If the 45's play OK then your belt might not be fitted in the right place. If they are both slow, then either the belt is slack or the drive is faulty.
Dec 09, 2012 | Audio Players & Recorders
What does the pnl lps fuse work or mean on a 94 check truck
That would be the fuse for the lights in the instrument panel or dashboard.
Jan 12, 2011 | 1994 Chevrolet C1500
Compressor will not engage
Look at the front of the ac compressor and have someone turn on the ac from inside the car. The front of the pulley(clutch) will spin when turned on.
If it does not spin, the low pressure switch (LPS) is not satisfied. Meaning there is not enough freon in the system to operate the system. Means low freon capicity because of a leak.
The LPS can be jumpered to cause the compressor to run (clutch to engaged) which will draw the freon in the system.
The LPS is usually a two wire sensor on the suction of the compressor. (between evaporator and compressor) Unplug the sensor and install a jumper, this will engage the clutch. Connect a new can of freon
and fill to system capacity.
The capacity of the ac system will be on a label under the hood, do not overfill. Probably about 2 lbs. Local parts stores (Auto Zone and Advance) will have freon with stop leak. This may help the leak. They also make a freon with a UV dye. I always add a single can with dye so that if stop leak does not work I can find the leak in the future.
The system should be filled until suction pressure is about 30 to 38 psi..
May 29, 2010 | 2006 GMC Envoy
Air conditioning not working
Below is a guide to troubleshoot and check system function. This can be done by most folks.
Remember the flow for the a/c system is :
1. From the compressor a high pressure (HP) gas goes to the condenser in front of the radiator.
2. From the condenser a HP2_bing.gif liquid goes to an expansion device (orifice tube or expansion valve)
3. From expansion device the low pressure gas enters the firewall to the evaporator.
4. From evaporator the low pressure liquid/gas mixture goes through the dryer2_bing.gif back to the compressor suction.
May 29, 2010 | 2006 Chevrolet Trailblazer
Have a 2000 vw bug a/c blowing hot air bought a home kit to fill it and when i put the gauge on it spun the needle all the way around. need to know what that means
Check to see if A/C clutch is engaging. If it is not engaging, the compressor is not starting which will prevent the freon from being sucked into the system.
If it does not spin, the low pressure switch (LPS) is not satisfied. Meaning there is not enough freon in the system to operate the system. Probably means a significant leak.
However, if it is empty the leak must be repaired.
The system should be filled until suction pressure is about 36 psi.
May 27, 2010 | 2000 Volkswagen Beetle
My 1990 Olds Cutlass Calais is missing the fuse box cover and therefore has no diagram for fuse placement. Is one available online? Copy I can print or just refer to in order to replace correct fuses?
I have always had a place in my heart for the Olds Cutlass. I own a '90 Olds Cutlass Calais--WITH the fuse box COVER. I went out to the car and removed the cover and have it next to me so that I can type the EXACT fuse order as they appear on the inside cover.There are 2 col. When I've finished the l/h side, I'll make a line to indicate the start of the r/h side. I will also put the Circuit on the left & fuse on the right. If you are ready, HERE WE GO:
-----CIRCUIT----------------------------------FUSE------
Air Cond/Heater HTR A/C
Audio Alarm CTSY LPS/GAGES
Driver Info System CLK-CIG/GAGES
Cigar. Lighter CLK-CIG
Clock (Radio) CLK-CIG
Cruise Control RADIO (LD2/LG7)
ECM RLYS (L68)
Eng Controls ECM RLYS
Eng Cooling Fan HTR A/C
Fuel Injection F/P INJ
Fuel Pump F/P INJ
Horn CLK-CIG
Ignition IGN
Instrumentation GAGES
Light-Lic Plate TAIL LPS
Light-Underhood TAIL LPS
Light-Glove Box CLK-CIG
Lights-Backup TURN B/U
______END OF 1ST HALF FUSE DIAGRAM______
-----CIRCUIT-----------------------------------FUSE-----
Lights-Brake STOP HAZ
Lights-Courtesy/Intr CTSY LPS
Lights-Hazard Warning STOP HAZ
Lights-Instrumentation INST LPS
Lights-Park/Side Mkr TAIL LPS
Lights-Tail TAIL LPS
Lights-Turn Signal TURN B/U
Power Antenna CTSY LPS
Power Door Locks CLK-CIG
PWR (CB)
Power Seats PWR (CB)
Power Windows CLK-CIG
PWR WDO (CB)
Radio RADIO
Rear Defogger GAGES
PWR (CB)
Torque Conv Clutch ECM RLYS
Trunk Release HTR A/C
Wiper/Washer WIPER
----------------END OF FUSE DIAGRAM----------------
Did my Best. Let me know if you need anything else. I have shop manual for this Yr, Make & Model. Best of Road to You. How'd I do? Have a Great Day!
Jan 03, 2009 | 1990 Oldsmobile Cutlass Calais
Deck
According to the owner's manual, the "deck" message means that your trunk is open. If your trunk is indeed closed, try opening and closing it a couple of times to see if it's not closing all the way due to an obstruction. If all this fails, you may have a bad fuse or connection that makes the computer think that the trunk is still open. Hope that helps!
Sep 09, 2008 | 1997 Chrysler Sebring
Aquacal Super Quiet Electric Pool Heat Pump Sq156 Logo
29 people viewed this question
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
