Question about Lands Phones
How do turn the ringer on?
This phone does not ring but still can make calls and answer them.
DIAL LCKED
Posted on May 03, 2013
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
safenude
  • 124 Answers
SOURCE: ringer off displayed on base
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Posted on Jan 28, 2009
SOURCE: GE phone has stopped ringing
I had the exact same problem and tried everything. It wasn't until I unplugged and main base from the electrical outlet for a few minutes and plugged it back in -- for some reason that made everything work. It is worth a try. We had some minor electrical outages in the last week due to weather so I assume that screwed something up.
Posted on Feb 02, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Posted on Dec 18, 2009
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Bt contour 200 does not ring ,ringer on and can answer a call just does not ring ?
Is it plugged into an extension socket? Make sure it is a master socket.
Jan 09, 2015 | BT Lands Phones
My kx t7730x doesnt have a ring but its receiving calls outside.
I'm guessing this is connected to a TA series system.
There is a ringer switch on the left side of the phone. Does it ring on intercom calls with the Auto Answer button not lit?
The 2 things that control the ringer for outside calls is the ringer switch and programming. Intercom calls ringing is controlled by the switch, Auto Answer button, and programming. If the switch is set to medium or high and the phone doesn't ring, try it at another extension. If it still doesn't ring, it's broken, if it rings, then you have programming issues.
Carl
Sep 11, 2009 | Panasonic KX-T7730 Corded Phone
Phone ringer
The box underneath the setup in the manual (mine's on page 13) describes what TOLL does. It can answer on the 3rd ring, the 5th ring, or if you have messages it will answer on the 3rd ring and not until the 5th ring if you don't.
You can hang up after 3 rings if the machine doesn't answer, because you have no messages. Other manufacturers call it TOLL SAVER.
Carl
Jan 12, 2009 | GE 27959GE6 Cordless Phone
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Let me know if you need further assistance
Jan 15, 2008 | Nokia 7250i
Contolling the volume
2 ways.
First way is a “User rated” method. That is: To turn off the ringer for that phone. Note that you will also have no ringing for internal calls as well.
Press:
[Shift key] until the RING displays above the [S2] key, press it and use the jog dial to turn off the ringer. Do the reverse to turn it on again.
Some users will turn on [Auto Answer] so they can still receive internal calls.
The 2nd way is in “Installer Programming” and will require a certified dealer/technician turn off ringing to that phone on that (or any) line/s.
Jan 08, 2008 | Panasonic KX-T7453 Corded Phone
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
