Question about Magellan eXplorist GC Handheld Geocaching GPS Navigator
My GPS has a warning sign that comes on when I turn it on saying 1000 GPX files loaded.Please consolidate additional files, I can't download any new caches I get can you tell me anything to fix it.
  • 3,287 Answers
It sounds like the maximum number of GPX file types your GPS can manage is 1,000. You'll need to delete as many existing GPX files as there are new that you want to add, ie: If you want to add 150 new waypoints (a.k.a. Geocaches a.k.a. GPX files) you'll should delete 151 (or more) GPX files from the GPS. That way, you'll have 999 GPX files loaded - and won't see the message complaining of 1,000 GPX files.
Running with a minimal number of GPX files may allow your device to run faster - as it doesn't need to load and calculate distances for 1,000 GPX file points. Less can be more - if you don't do CITO, Webcam, Multis, etc. or any type that has a difficulty / terrain ratings greater than 2 or 3, don't even download them. It's just clutter for your GPS to track and manage.
Look at the filters to select the types you want - either on Geocaching.com or the software (GSAK?) you use assemble and prepare for loading them into your GPS.
Posted on May 03, 2013
How Can I download GPX & Photo from hanged GPS with number of restart at a minute?
Contact Garmin Customer support: on their web-page, or: 1 (913) 397-8200. They are very helpful.
May 04, 2014 | Garmin Oregon 550 GPS Receiver
Geocache list doesn't show on gps
Basecamp is displaying the contents of the gpx file. This means you've correctly imported the gpx file into Basecamp.
A copy of the gpx file needs to be separately saved into the "GARMIN/GPX" folder on your GPS via USB and your computer. (Note: I believe your Oregon has the same file structure as my Garmin Montana).
On startup, your GPS will read the new data and display the caches.
Mar 27, 2013 | Garmin Oregon 450 Handheld GPS Receiver
How do i reset my garmin colorado 300
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:\Garmin on your PC.
On your PC click the Start menu, select "Run..." and type "cmd" where it says open. A black window with a DOS command prompt should appear. At the command prompt enter the following command:
> cd c:\Garmin
At the next command prompt type the following command without hitting enter:
> Updater.exe 066101000230.rgn
Now back to your GPS.
Press and hold the "up button" on the Rock'n Roller while you plug the CO into the USB cable. Wait 10-20 seconds while still holding the "up button". You should see a Garmin banner and nothing else. At this point you can hit enter on your PC to execute the updater command. Once the updater runs you will need to select you Colorado under USB and hit enter. This should perform the update (you may get a warning about loading an older version of software). You should receive a message that the update was successful and the Colorado will reboot.
Once the reboot is complete the "Loader" banner should appear near the top of the CO screen after about 30 seconds. Release the "up button" and on your PC you should be able to see the Colorado as a USB drive.
You can now attempt to fix the files on your Colorado which are preventing it from starting. If you've recently added or changed files these are good places to start. Deleting gpx files and/or replacing map img files with your backup copies may resolve the issue as well.
May 07, 2011 | Garmin Colorado 300 Handheld GPS Receiver
Problem with our Garmin you can turn it on and it will not do anything but display Garmin name and will not turn off. Have changed batteries, any ideas???
It sounds like your Garmin has a corrupt file or file system. This is common when using bird's eye imagery with unsuspected shut-downs.
Try doing a soft reset of the Garmin:Warning: This procedure will delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
1. Power the unit OFF
2. Hold down the two Soft Keys for 2 seconds
3. While continuing to hold the 2 Soft Keys down, press and hold down the Power button for an additional 5 seconds
4. Release all buttons, and select YES to the prompt asking "if you want to clear all user data?"
This form of reset does not seem to reset all of the settings to factory defaults, just a few of the basics like Time Zone and Language, the remainder of the settings are still taken from your existing profile files.
Once you have completed a reset remember to place the Colorado outside in a stationary position for 20 minutes in plain view of the sky so that it can rebuild the almanac before using it again.
Note: Holding down both soft keys and the select button in a similar fashion seems to do a similar reset to the Colorado. This may be a master reset.
If the problem still persists, try this as a last ditch effort.
Warning: This procedure may delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
If you can't get your CO to start properly and it will not go into USB storage mode when connected to your computer you can try this as a last ditch recovery. It worked on a 400t that would freeze when loading maps and soft/hard resets didn't not work, I've also used it to recover a Colorado which refused to boot because of a bad gpx file.
First you'll also need to download file below. Once you've downloaded this file unzip it into a directory such as C:Garmin on your PC.
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > cd c:Garmin
.text { font-family: monospace; }.text .imp { font-weight: bold; color: red; }.text span.xtra { display: block; } > Updater.exe 066101000230.rgn
zip.png Colorado_Mass_Storage.zip
Feb 07, 2011 | Garmin Colorado 400t
Garmin nuvi 1340 freezes on start up
If your nuvi series device is freezing on the map screen but still providing voice prompts there are two steps you can try to resolve the issue including updating the software using WebUpdater* and performing a master reset.
To download WebUpdater and update the software:
  1. Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen instructions.
To perform a master reset on your nuvi series device: CLICK HERE
Warning: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Garmin nuvi 1300 Car GPS Receiver
How do you get geocaches on a lowrance endura gps. plez help
Loading Geocaching information on the Endura Safari GPS
You can load individual caches into the Safari as a .loc file or load a pocket query file of up to 500 caches as a .gpx file.
The trick with the Safari is to load these onto the unit using the data cable that comes in the box. Connect the Safari to your computer using the data cable and transfer your .loc or .gpx files into the GPX folder on the device.
These files have to be in this GPX folder to be recognized by the device. It will not work if you load the .loc or .gpx files onto a microSD card and insert it into the bottom of the Safari. I am told that this will be fixed in the 1.2 software update that is supposed to come out at the beginning of December.
Once you have the files loaded, all you have to do is disconnect from the computer and wait for the Endura to restart, go to Main Menu --> Find --> Geocaches and see all of the caches listed. For .loc files, there will be limited information provided from Geocaching.com. For .gpx pocket query files, you will have access to the full description, cache size, terrain difficulty, find log and hints. The great thing about the Endura GPS products is that they have a great filter function for geocaches. I use this with my 7 yr old daughter when I only want to find caches that are easier to find and have full size traditional caches that are more likely to have better "treasure" inside. Hope this helps. Have fun!
Nov 15, 2009 | Lowrance Endura Safari Handheld GPS...
What is a GPX?
What is GPX? GPX (the GPS eXchange Format) is a data format for exchanging GPS data between programs, and for sharing GPS data with other users. Unlike other data files, which can only be understood by the programs that created them, GPX files actually contain a description of what's inside them, allowing anyone to create a program that can read the data within.
How can GPX help me? GPX lets you exchange data with other GPS users, who might not be using the same software as you. Imagine the following scenario:
You're leaving for vacation tomorrow, and you wonder if anyone has some waypoint data for the tropical paridise you'll be visiting. You do a quick search on the web, and find a data file created by a GPS user who just returned from vacation!
You've found some GPS data you can use on your vacation! Perfect! Or is it?
Without GPX You download the file, Vacation.txt from the vacation webpage, and try to open it with your GPS software. It crashes. Even though your GPS software reads and writes text files, this one is a bit different. You try making some changes by hand, but it's taking too long, and you're afraid you'll make mistakes. You do a quick web search to find a solution, but no converter exists. You end up printing out the text file and entering some of the waypoints into your GPS by hand. On the second day of your vacation, you realize that all the waypoints are off by a quarter mile. It turns out the website owner had his GPS set to a different datum, and you forgot to change your GPS before entering the data by hand.
With GPX You download the file, Vacation.gpx from the vacation webpage, and open it with your GPS software. You're surprised that it opens and transfers successfully to your GPS, since the file was created by a Lowrance GPS user on a Macintosh computer using a program you've never heard of. But since your GPS software supports GPX as well, you now have a complete, accurate set of waypoints for your vacation.
Feeling lucky, you wonder if there's a way to get the waypoints into your new street mapping software, so you can plan a route from the hotel. Your street mapping software doesn't support GPX, but maybe there's a converter available? A quick search on the web turns up another webpage! You wonder how much it's going to cost to buy a program just to do the conversion, but it turns out you don't even have to install new software - the webpage uses a FREE online form to convert your GPX file. You click the Submit button on the form, and your web browser launches your street mapping software with the converted data.
The next day, lying on the beach, you think about how easy it is for GPS programs to exchange data using GPX. While sipping a cool drink, you remember that anyone can write their own GPX converter to transform GPS data into a spreadsheet, a personal webpage, or a data file for their favorite program. And you think to yourself, "GPX really is a better way to exchange GPS data."
What are the benefits of GPX? Here are some of the benefits that GPX provides:
  • GPX allows you to exchange data with a growing list of programs for Windows, MacOS, Linux, Palm, and PocketPC.
  • GPX can be transformed into other file formats using a simple webpage or converter program.
  • GPX is based on the XML standard, so many of the new programs you use (Microsoft Excel, for example) can read GPX files.
  • GPX makes it easy for anyone on the web to develop new features which will instantly work with your favorite programs.
For more information, refer to :-
http://en.wikipedia.org/wiki/GPS_eXchange_Format
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 02, 2009 | GPX Audio Players & Recorders
Wont copy songs to mp3 player because of write protection
please see the info here
http://www.gpx.com/store/p/334-MW238P.aspx
please info if it helps..
Nov 19, 2008 | Audio Players & Recorders
Unable to send and open data sent to my Garmin GPS from Anquet map. I planned a route on my Anquet map software with wayponits etc but was uable to send it to my gps. I have enquired with Anquet and they...
Currently, the POI Loader only supports CSV files because that is the format that most data vendors support. POI Loader may support additional formats in the future.
MapSource only supports .mps, .gdb and .gpx files. You can save files as .txt files if you wish to use this data in other applications.
Sadly Garmin does not produce any software which can convert .txt files.
However, this maybe possible with GPS Utility. Please note GPS Utility is not Garmin software and Garmin does not support this. Click on the following link for more information:
www.gpsu.co.uk
Oct 13, 2008 | Garmin GPS
.GPX files on handheld Lowrance?
I sugust that you call the Lowrance customer service department @ 1 800 324 1356. They are very friendly and will work with you. Good luck
budman630
May 15, 2008 | Lowrance iFinder GPS Receiver
Magellan eXplorist GC Handheld Geocaching GPS Navigator Logo
111 people viewed this question
Top Magellan Sport & Outdoor - Others Experts
Are you a Magellan Sport and Outdoor - Other Expert? Answer questions, earn points and help others
