Question about HTC Flyer 7 inch 32GB Android Tablet PC with WiFi and 3G
Htc wont charge and turn on - HTC Flyer 7 inch 32GB Android Tablet PC with WiFi and 3G
    New Friend:
  • 8 Answers
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
Posted on May 02, 2013
My ipad wont turn on
what model of ipad is it if its the third then its probably dead you need a different charger than the one apple supplied if you have or know anyone with maybe a Samsung charger for an s3 or s4 use your cable but use there Samsung plug it has a usb slot on it and would provide more power to charge it as the third gen drains very quickly and the charger they supplied isn,t enough to keep it going
Apr 22, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Htc tablet pg41400 restrat problem
it might be problem with system software... i think
it wants to reload the operating system...
Mar 27, 2014 | HTC Flyer PG41400 1.5GHz 1GB 16GB 7in...
Htc amaze battery life
Oops, it does not have to be, at times, I meant, supposed battery failure
If the battery contacts/pins for your phone/tab are not making contact well with the battery terminals/heads...you will experience such, constantly.
If the battery does not sit/fit well in its compartment, you will still experience same as you do at present. This is because, the battery is making partial contact with the terminals/pins.
Check these; whether your battery sits well and fits perfectly in its compartment inside your phone/tab.
Check whether the terminals are contacting well
Aside of these, you may need to either replace your cellphone/tablet's battery and watch what happens.
Feb 05, 2018 | HTC Amaze 4G Android Smartphone
HTC sensation X315e charging problem
Leave it on until all power gone then hold down power button for 30 sec's and the try charging.
Jan 15, 2014 | HTC Tablets & eReaders
I connect my HTC HD7 from a wall charge and is not charging.
it sounds as thow you got a faulty wall charger it happens a lot, and if its not than your battery is gone that happens when you leave it plugged up after its fully charged, it over heats the battery and eventually it will not charge
Apr 15, 2013 | HTC HD Windows Phone 7
My HTC Amaze shut down and wont turn on or charge even with battery change
Try leaving it on the charger for a few hours and see if that helps.
Apr 03, 2013 | HTC Amaze 4G Android Smartphone
Htc amaze 4g wont turn on after charged
Try leaving the battery in with it charging all night, if the phone won't turn on after that, you'll need to exchange it.
Jan 16, 2013 | HTC Amaze 4G Android Smartphone
I connect my htc sensation xl to the pc and its not working, instead my phone turns very hot
Whenever you connect HTC Sensation XL with Beats Audio to a computer using the USB cable, the Choose a connection type screen opens and lets you choose the type of USB connection.Select one of the following choices, and then tap Done:Charge onlySelect this option if you only want to charge the battery while connected to your computer.Disk driveSelect this mode when you want to copy files between HTC Sensation XL with Beats Audio and your computer.
When on Disk drive mode, you will not be able to use apps on HTC Sensation XL with Beats Audio that access the storage such asCamera.
HTC SyncSelect this option to synchronize contacts, calendar, and other information between your computer and HTC Sensation XL with Beats Audio.USB tetheringWhen you do not have an Internet connection on your computer, you can select this mode to share the mobile data connection of HTC Sensation XL with Beats Audio with your computer.Internet pass-throughIf you don't have a data plan or you don't have access to a Wi-Fi network, you can select this mode to share your computer's Internet connection with HTC Sensation XL with Beats Audio.
Oct 10, 2012 | HTC Sensation XL X315E with Beats Audio...
What are other causes of a phone not turning on besides a dead battery, overheating, and freezing?
replace the battery for starters
check that the charger is putting out the correct voltage
Jun 05, 2017 | HTC HD Windows Phone 7
HTC Flyer 7 inch 32GB Android Tablet PC with WiFi and 3G Logo
1,208 people viewed this question
Top HTC Tablets & eReaders Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
matt
matt
Are you a HTC Tablet and eReader Expert? Answer questions, earn points and help others
