Why vga fails to display when you connect t acomputer?
  • Computers & ... Master
  • 5,660 Answers
Display is working on internal monitor of laptop?
Then the problem is;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno.
Laptop manufacturer name, and model number was not stated.
Model number is on the Bottom of the laptop.
It will be one of the F keys at the Top.
F1 through F12
GENERALLY it's;
F4 for HP or Compaq
F5 for Acer
F5 for Toshiba
F8 for Lenovo/IBM
Usually has a monitor icon on the F key, (Looks like an empty rectangle, with rounded corners); and an arrow off to one side.
Still no?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
Post back in a Comment
Regards,
joecoolvette
Posted on May 02, 2013
No input signal on a HP 1530 monitor
Then the PC video board may may failed.
Jan 26, 2017 | HP Computers & Internet
VGA-HDMI connection fail on Acer projector using adapter
You don't say whether or not the "adapter" is simply a gender-changer, or if it actually converts the digital signal from the HDMI port to an analog one for the VGA port. Some monitors have both analog and digital input capability and can automatically adapt to the the digital signal, even if applied to the VGA (analog) port. Other devices are not so smart and need an actual digital-to-analog converter style adapter.
Jul 06, 2016 | Acer XD1170D Projector
What makes acomputer does not display
1.Check if the RAM is okay. try replacing if faulty because the computer depends on it to display
2.try to connect the computer to an external monitor and see if it displays...replace the LCD or check its cable for any loose connection
if the two options does not work out for you then write in details for further assistance.....how this is helpfull to you
Nov 14, 2014 | Toshiba Computers & Internet
I have a dual display with a Samsung digital LCD flatscreen and LG analog LCD flatscreen running on WinXP with a nVidia GeForce 8400GS video card. The video card is new - the old card (which was hooked up...
Hi
I'm not sure what you mean by VGI. I will assume you mean VGA (Analogue - D Shaped with 15 pinholes).
When pixels or line of lixels fail on a monitor, they usually fail in spots or in a vertical lines due to the design of the matrix.
Since both monitors are sharing a single cable and the graphics card is a new one, the fault automatically isolates itself to either the monitor or its VGA connector.
Check that none of the pins in the end that connects to the faulty monitor are bent and/or touching one another and shorting.
Then try changing the resolution of the graphics card itself and test the monitor's performance at various settings to see if the resolution seeting is straining against the limits of the monitors range.
Right click on open space in the desktop > properties > settings > click and hold the slider scale step by step, up and down the scaled to test the monitor > apply > ok > test for a reasonable period > reset.
Also test the monitor with a single VGA cable to another computer (even a laptop, using the Fn key + external monitor function key).
Thses tests should tell you if the monitor is failing.
I hope this helps.
Aug 24, 2011 | Computers & Internet
Need a Monitor cord. What should I get?
If it is a signal cord from computer, you want to get a VGA cord. if it is a power cord, Same as a power cord for acomputer, and you can get them at radio shack, of best buy.
Aug 11, 2011 | ViewSonic Optiquest Q53 (White) 15 in.CRT...
No display with vga or dvi, but "no signal" without cable
Stick with the VGA cable. You have tried several PC's but are you also using the same cable? Bad cable perhaps? How about software conflicts? Really should not be an issue as most are plug and play.
Try connecting a laptop to it with the VGA cable. Use the Function "FN" key with the F series on top row...the one with the LCD or monitor icon on it, usually F5, F7 or F8. This tells the laptop that you have connected an additional external monitor to it. If that fails, something is faulty with the monitor and there is not much I can do to help. Sorry...but let me know about the laptop connection.
Jun 30, 2010 | Princeton Digital VL2018W Monitor
My HP Monitor Model No: L1706 problem
I sure sounds like you have backlight problem, since when the VGA cable is connected the power LED turns GREEN and blinks when VGA cable is disconnected, it means the video signal is getting to the monitor OK, so more likely the problem will be in the monitor, but just to be sure, you should also try this monitor with another PC first.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | HP L1706 17" LCD Monitor
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Power light flashes with no display
That usually means that the connection between the PC and the monitor has been interupted- check that the cable (probably has blue ends) between the two is firmly connected, and power it back up. If that doesn't work, you have one of three problems; a broken VGA cable, a broken monitor, or a broken video card. Finding out which- you'll actually need someone tech-savvy there to help you figure that out. Try plugging the monitor into a different computer. If that fails, use a different VGA cable (cables are pretty cheap at monoprice.com), and if that fails, it's your video card.
May 23, 2007 | Mag Innovision InnoVision 786 PF 17" CRT...
Computers & Internet Logo
David Payne
David Payne
