Question about ASUS Eee PC 1015PX Netbook
My ASUS eeePC won't run
Hello, i have a problems with my netbook. It started normally then it suddenly turned off. I try to turn it on, but pressing the turn on button only makes the lights on for a while then turned off again.
    Novelist:
  • 148 Answers
When I and or friends have that symptom I normally start by disconnecting the power to it, that includes removing the battery, but as I write this I am thinking some Netbooks, Notebooks have Batteries encased, making it more difficult for the faint hearted owners to try and replace batteries when the needed. But yeah try that as most of the time that has helped me, if that doesn't work then we have to try and establish if Software problem OR Hardware, so good luck and please let us all know if that worked.
Posted on May 03, 2013
gsessons
  • 26 Answers
SOURCE: asus dont turn on
try this
1st. turn off laptop
2nd. unplug power supply
3rd. remove battery
4th. let stand with out any power for about one min
5th. put battery back on
6th. place the power supply back in
7th. turn computer back on.
Should work!!!!!!!!!!!! Good Luck!
Posted on Jan 25, 2009
camille zar
  • 95 Answers
SOURCE: I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Posted on Aug 05, 2009
  • 218 Answers
SOURCE: cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Posted on Jan 02, 2010
  • 9 Answers
SOURCE: How do i open an Asus eeePC 1008HA netbook to
i think this link can help u
http://www.liliputing.com/tag/ram-upgrade
Posted on Mar 15, 2010
Davethesnake
  • 689 Answers
SOURCE: Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Posted on Sep 05, 2010
Netbook Screen Turns to White Noise after Turning on within 1 Minute
Could be a problem with the flat cable (the connection from video to motherboard) but since your screen starts to fail after a little time could be a problem with the integrated Intel GPU too.
If your model has the second GPU (Like Nvidia Ion) try to disable it and see what happen.
A good test is to turn on you netbook and leave it on Bios settings page to see if the issue is software related or not.
Another test is to hook an external monitor (if you have a VGA or HDMI port available) and see if the GPU is ok.
If the problem is the flat cable you can try to replace it but if you have a faulty GPU and you are out of warranty you need th replace the entire motherboard because normally GPU is part of the chipset and can't be replaced.
Sep 05, 2012 | ASUS Eee PC 1015PXPU17RD Netbook
Need to find a way to reboot an Asus eeePC 1005 PEB-RRED01S
What is the problem? Why won't it reboot? Does it get power and try to reboot? Give us more details and we'll get it booted.
May 19, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
ASUS EEEPC 1215N battery won't charge with a "Plugged in - 0% remaining" I already had the same problem. ASUS service fixed it with BIOS update. But I don't know what they did exactky. an...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 13, 2011 | ASUS 1215NPU27RD 121Inch PC Netbook
The Fn keys on my asus eee pc1015 suddenly won't work (only the brightness keys working). I got an error pop up that says something about the asus vibe that didn't work properly. what could be the...
stuck fn key ????
try turning the unit up side down and (lightly) tapping on the unit.. some thing could have go caught under the key ..
Hope this helps
Sep 20, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Is an Asus Eeepc 701 Linux OS & firfox browser compatible with a wireless N wifi router?
Yes, but the netbook only has a G card, so it won't be able to perate at the higher speed, and you'll have to make sure the router is in Mixed mode.
Sep 02, 2011 | ASUS Eee PC 701 Notebook
My computer won't turn on, it just has a blinking dash on the left hand side I've tried turning it off and on multiple times and nothing will work I have an assigment due at the end of this week...
while the computer is turning on push the escape key and try selecting the harddrive
if it doesn't start to boot into windows then your boot record is probably corrupt you can try fixing it by running chkdsk /r on your OEM reinstall disc that came with the computer, seeing as you have a netbook you will need a external cd rom
Jun 14, 2011 | ASUS Netbook
My Webcam is built in and my computer is not recognising it. i went into its software and it told me to try to turn on integrated webcam. i am using windows 7 starter and i need my webcam.
download and install: 1. ecam utility http://dlcdnet.asus.com/pub/ASUS/EeePC/Utility/ECam-V2_0_2_3.zip
2. Livcam Utility http://dlcdnet.asus.com/pub/ASUS/EeePC/Utility/LivCam-V1_0_9_1.zip
Aug 11, 2010 | ASUS Eee PC 1005PE (SeaShell) Netbook
The keyboard has suddenly got limited function
I have the same problem with an Asus Eeepc 900HA. I am trying to solve, if you solve firts write to me to jhonald@redesfx.com, thanks
Jul 11, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
ASUS Eee PC 1015PX Netbook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
