Question about Frigidaire Affinity ATF7000E Front Load Washer
E31 - Frigidaire Affinity ATF7000E Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello Stephanie - If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Posted on May 03, 2013
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
What is E31
E31 is comm failure. If whenn power is re instated and E31 is still present replace the pcb and reinstate power.
Mar 03, 2015 | Heating & Cooling
E31 error code on electrolux washing machine
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
Jun 08, 2014 | Electrolux EW1000i Front Load Washer
ERROR CODE E31
Hi and Welcome to Fixya!
E31 simply means - Waste Toner Reservoir Overflow Problem (when the total number of copies is more than 100K sheets). After E31 is displayed, 1000 sheets may be copied before shutdown.
Hope this helps!
Takasashi
Jul 13, 2011 | Kyocera Copystar CS-1620 Black and White...
Error E31 on Bushnell V2
Can you check that the new battery is an alkaline battery? If it is, and you are still getting the E31 error code, you will need to return your rangefinder to Bushnell to have it reprogrammed.
E31 is a programming error code. Most of the time this comes from using non-alkaline batteries or from letting a battery die in the unit. Non-alkaline batteries just don't generate enough current for the laser to operate properly.
Good luck.
Feb 28, 2011 | Bushnell Tour V2 Pinseeker Laser...
Affinity dryer with a e31 error. What should i do?
I have the same problem . The store replaced it with a brand newnew unit - SAME E31 error code appears and there is no solution
Oct 26, 2010 | Frigidaire Electric Dryer
Canon DR7580 error code e31
E31 refers to abnormalities in mechanical Counter. Check if it is installed properly. The scanner can work without this also.
S. Mohan, Chennai, India
Sep 24, 2010 | Canon DR-7580
Bushnell Rangefinder Tour v2 E31 appears in viewfinder
If it is 2 years or less from the date of purchase.....send a copy of the POP (proof of purchase) or call them......! It should be under warranty. This is the real deal!!!
rate if you can!!
MTG
Jun 12, 2009 | Bushnell Optics
E31
Hello Smithysarah,
Welcome to fuixya,
You said, HI MINE READS ERROR E31 WHAT DOES THIS MEAN?
E30 or E31= Motor Drive Problem -
Run the programme again,
if problem persists call for
a Service Engineer.
I will tell you a secret.
Try unplugging the washer for 5 minutes and then we will see if this has reset the system!
like rebooting your computer.Some times it is only a glitch and no mechanical problems are there!
If so you saved a service call.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank you.
Waiting for your results!
Sep 30, 2008 | Hotpoint Ultima WD72 Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
385 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
