Question about Sony CFD-S300 Radio/Cassette/CD Boombox
No volume when trying to play cd.
When I try to play a CD, the machine reads the CD, and spends it but I get no volume or sound.
  • 6 Answers
SOURCE: Will not read cds
Your problem may be the picup assembly or need cleaning not with cloth there are special cd's for that purpose.
Posted on Nov 01, 2006
Arpi
  • 326 Answers
SOURCE: Sony DAV-SC5 Home Theatre System problem playing CD-RW's
Hello, your home theatre system is from the year 2003. Maybe a cleaning the optical can solve the problem. There are cleaning CD kits on the market, but better option is if a pro does it (the cleaning) for you. If you need more assistance please advice. Arpi
Posted on Mar 22, 2007
thesoundman
  • 41 Answers
SOURCE: sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
Posted on Sep 21, 2007
dobhan
  • 105 Answers
SOURCE: CD plays CD's intermittently does not recognise some CDs
in my side i already encountered that problem.this is what eve done,i'm just clean the lens with cotton and one drop of alcohol, after cleaning,its work.....just follow what i'm doing....
Posted on Jan 25, 2008
Th3_uN1Qu3
  • 47 Answers
SOURCE: The CD player on my Sony Dream Machine FM/AM CD
The laser has gone weak. If you feel confident taking it apart, unplug it and look for a small potentiometer on the CD reading pickup. Turn it to the right to about 700 ohms, it should start reading again. If you don't have a multimeter to measure it then get one, a basic $10 meter will do fine.
Posted on Jun 26, 2009
Why is my Insignia ns-b3112 have sound on the radio but no sound on any cd's?
hi have you tried putting a cd cleaner in it because over time the lens which reads the cd can become dusty making it impossible for it to play hope this helps
Oct 14, 2016 | Insignia Boombox NS-B3112
Bose sound
You could try to clean the laser, with a special cleaning disk. Don't try to clean a laser by opening the player, you will damage the system.
If it is a CD burned in a PC, it also can be the laser is now a bit less, not capable reading CD-R or CD-RW, and still can read normal CD's
Read my other post over CD players
Jul 26, 2014 | Bose & Wave& Music System
Copied CDs won't play with my Aiwa LCX 350 shelf system. It will spin for a bit, then stop. I've tried every method ... with or without remote, start/stop, etc. This doesn't happen with any retail CD. Only...
It sounds like it's not reading the CD. 2 things to try, neither of which are guaranteed to work:
1) Try changing the brand/colour of your recordable CD.  Some machines read different colours/brands better than others; particularly older CD players.  If the ones you have are all light-coloured, try burning a couple of dark-coloured CDs and see if that helps
OR:
2) It could be the speed at which you're recording.  Try burning a CD at 1x speed and see if that helps.
May 26, 2010 | Aiwa Audio Players & Recorders
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
CD changer won't play CDs.
time to clean the lens...get a good CD lens cleaning kit
Aug 12, 2009 | Bose Lifestyle 25 System
No sound and cd read Paused
I had the same problem a few times. I found that it went into pause mode when the CD was playing and the volume was turned down to zero. Try turning the volume back up. The CD should exit pause mode.
Aug 06, 2009 | 2005 Volvo XC90
10-year-old Kloss, model 88 stopped playing, suddenly.
Sounds like a cold dry joint connection problem internally ,needs to be serviced
Jan 14, 2009 | Cambridge Soundworks 88CD CD Player
T6216 CAN'T USE CD BURNER ERROR MESSAGES INDICATES NO CD DRIVE
Sounds like your CD drive is gone. Try inserting a program cd and see if it reads it. You can also switch the cable attached to the cd drive. Make sure you get a power light on the cd drive when you start the PC, if not you can try a different power connector from the power supply. Hope this helps.
Nov 06, 2008 | E-Machines eMachines Desktop PC
Cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Jun 09, 2008 | Tascam CD-RW4U CD Recorder
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
BD
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
Sony CFD-S300 Radio/Cassette/CD Boombox Logo
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
