Sansui tu-x310 - Televison & Video
I am asking for Sansui plasma TV codes pls!
The codes for a universal remote to work with a Sansui television are:
Sansui television remote code 834
Sansui television remote code 0310
Sansui television remote code 0394
Sansui television remote code 20695
Sansui Google Search
Dec 27, 2016 | Sansui Televison & Video
X310 lawn tractor
What is your question ?
Jul 30, 2016 | Garden
What type of connection wires do I need to connect a sansui au 9900a intergrated amplifier,and the tu9900 stereo turner to a kenwood multi cd player and a JVC td- w 5th double cassette.
You need cable called RCA. What goes out of one unit goes in to another. Get the owner manual and read it. It will show you how to connect the wires to the components.
Connect the RCA jack to to tuner input in back. CD player to the aux in back.
Try this:
http://stereobarn.com/how-to-connect-a-stereo-system1/
Sep 29, 2014 | Sansui Vintage Tu-9900 Legendary Amazing...
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
Panasonic rc x310 schematic how to change the time.
youd have to buy the manual or email me close-up pictures of the radios at markusmaritz333@gmail.com else visit http://service-manuals-schematics.com/purchase.php?id=Panasonic+RC-X310+Service+Manual+%2F+Schematics .
Please rate.Thanks
Nov 21, 2013 | Radio Communications
No funciona teclado
Apaga tu computadora, desenchufa tu cargador, remueve tu bateria, aprieta el boton de apagar asia la derecha por 30 segundos. Ahora pon la bateria y conecta tu cargador y prende tu computadora. Esto devera ayudar a tu teclado a servir otra ves. Espero que esto te ayude. Buena suerte!
Sep 30, 2013 | Computers & Internet
My sansui tu 217 makes a popping noise and looses all volume when i turn it above 1
Volume controls these days pass signals to an IC that controls most functions such as volume and tone. Following the wiring from the volume control should take you to the this IC which will need to be replaced.
Jun 19, 2013 | Audio Players & Recorders
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
Tuning without a remote
pls use panel menu key prees and select tuing menu and see display in ASM [auto serch memory] select ASM befor ch.no set is "0" and select ASM .
use panel ch+ ch- is up and down select key is v+ and menu key is menu next page
Oct 08, 2009 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
