Question about Panasonic KX-T7730 Corded Phone
Want to divert phone to a cell no. any assistance please
My Ilink Q900 cell phone cannot dial. When trying to make a call, an error message reads "not allowed to dial" please help
It seems your mobile calls have been diverted
Go to Call divert option and cancel all diverts
Jun 04, 2011 | Cell Phones
How to deactivated divert call my phone GT-S5233W?
I have a samsung GT-S3353 can you please suggest how to cancel call divert facility
May 24, 2011 | Samsung Star GT-S5233 Cell Phone
MY PHONE IS SWITCHED ON, BATTERY AND SIM CARD CORRECTLY INSERTED BUT WONT ACCEPT CALLS. IT AUTOMATICALLY DIVERTS TO VOICE MAIL. PLEASE HELP
Hello Damien barlo, I have a solution for you. Please remember to provide me POSITIVE FEEDBACK so that I can continue providing expert solutions for free.
Please remove both the battery and your phone from a charging jack. Remove the SIM card and replace the SIM card in firmly. If you have a storage flash card, then ensure to remove that as well as replace it back into the phone. Next, step outside the home and set the phone down on the ground all allow it to find a signal on its own without you having to move around to find the best signal. If you have a second phone, please try to call your cell phone to see if it rings correctly without going to your voice mail. If your problem continues, please come back for more free expert solutions.
Thank you,
Jan 11, 2011 | Nokia 6300 Cellular Phone
Can I get my incoming phone calls rerouted on to my Mobile, the number is 07804626799.? your assistance would be much appreciated
Yes sir u can definately do that ,, there is a divert option in your phone ,i mean call divert , select that punch in the no. u need the calls to get diverted click ok and done , ,still if u r confused abt it , u can mail me at cellphonez99@gmail.com
Dec 03, 2010 | Cell Phones
My Genio goes straight to voice messaging can't deactivate
hi you need to enter settings then call settings then call diverts then cancel all diverts then this will allow the phone to ring,
then turn on only the diverts you want on such as when out of reach or when not available this will then let it go to answer phone when the phone is off.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 30, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I have tried to turn off the call divert function on my phone but it still diverts calls. I have followed the following steps. Tools>Call Divert>Voice Calls>toggle across to Divert: off and then...
call divert is something more concerned with ur service operator than ur phone. some operators have some special sms's to be sent for cancelling call diverts. please verify with ur customer care.
Feb 16, 2010 | Motorola Mobility Motorazr2 V9x Cell Phone
Warning notes"active divert"in my nokia 5700
Go to Tools>Settings>Phone>Voice Calls>All Voice Calls ... And when you select, you can check Status, Cancel ALL Diverts or Activate Diverts.
(In your case please select CANCEL so that you won't get that message whenever you place a call)
Thanks.
Jan 17, 2009 | Nokia 5700 Cellular Phone
Incoming calls
What you need to do is go to settings then call then call divert, and then cancell all diverts. This should hopefully solve your problems once you have done this you can choose what call diverts you want to use. Such as when the phone is off (divert if not available)
If you don't have signal it is probably the arial and will most likely need replacing.
If you need further assistance let me know!!
May 03, 2008 | Nokia 5300 Grey Cellular Phone
PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Feb 15, 2008 | Pantech C120 Cellular Phone
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Jan 15, 2008 | Nokia 7250i
Panasonic KX-T7730 Corded Phone Logo
52 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
