Question about Garden
Watchman niveau problems
I am not getting any signal bars on my plug in house monitor, to indicate how much oil is in my tank. i have had the system instaled three years ago. what is the problem' thanks
5 Suggested Answers
  • 38 Answers
SOURCE: chainsaw is using way to much bar oil
there should be an adjusting screw usually at the front of the saw, on most saws. usually located on the lower front. the screw puts tension, or less tension controlling the flow of oil. also if that did not help then you might have a broken oil line or it might be diconnected all together.
Posted on Feb 20, 2009
  • 4088 Answers
SOURCE: POWERCRAFT PC40-38cc.THE CHAIN OILER DOES
It would appear that you must 'go under the cover'. Look for a damaged oil line or split oil tank. The oil pump may have come loose from it's mounting. Be sure to check the oil filter for plugging. Hope this helps!
Posted on Dec 22, 2010
SOURCE: My husqvarna 455 rancher isn't oiling the
same issue here any buddy find out what is
Posted on Nov 26, 2012
clayton_olso
SOURCE: Bar oil leaking constantly. How do I fix it?
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Posted on Mar 10, 2013
My 2001 saturn is trying to turn over and start but wont check engine light code p0452
P0452 Saturn Fuel Tank Pressure Sensor Circuit Low Voltage
"P0452 - Evaporative Emission Control System Pressure Sensor Low Input. Evaporative Emission Control System Pressure Sensor Low Input indicates a low voltage problem in the Fuel Tankicon1.png Pressure Sensor (FTPS). What the fuel FTP sensor does is convert fuel tank absolute pressure into electrical signals and inputs the signal to the ECM/PCM, (Computer).
First thing to do is make sure the gas cap is good and tightened properly. Then check the vacuumicon1.png lines and wiring at the FTPS (Location-Fuel Tank) to be sure they are good, clean and tight.
Barring a wiringicon1.png problem it can be a bad FTPS or PCM.
I copied this blog on the code p0452. So, check gas cap, check vacuum lines from fuel tank and trace the lines making sure there is no break. check wire plug on the fuel tank pressure sensor.
May 16, 2014 | Cars & Trucks
Tip
SAFEGUARD YOUR HOME/BUSINESS WITH HONEYWELL'S WINTER WATCHMAN!
I recently discovered a great device, manufactured by Honeywell which is guaranteed to provide you with peace of mind whenever you are away from your home or business for more than a few hours. The Honeywell Winter Watchman UPC#: 085267870511, is a freeze warning alarm. Winter Watchman turns on a light alerting neighbors of a cold, low temperature condition. The model number is S483B1002 and the cost is in the $25.00 - $30.00 range.
This device plugs into a home outlet and then you plug a lamp into it. Make sure the lamp is on before you plug it into the Winter watchman. I use a lamp with a red globe and place it in the front window. Then I notify all of the helpful neighbors of my warning system so that can call me,or my designee, if they see the red light on. One of the features of the Winter Watchman is the fact that you can set the warning temperature, ten degrees below the setting on the thermostat would be a good setting in that the warning light would activate but your home wouldn't be in danger of an immediate freeze of the water pipes. OTHER modifications you might consider would be:
1. plug a spot light with a red bulb and a flasher unit into the Winter Watchman to get everyone's attention.
2. Use more that one Winter Watchman, perhaps on the other side of the house so that multiple neighbors can be alerted.
on Dec 23, 2009 | Kitchen Appliances - Others
POWERCRAFT PC40-38cc.THE CHAIN OILER DOES NOT APPEAR TO BE WORKING! NO OIL IS COMING OUT THE SMALL HOLE IN THE HOUSING THAT THE BAR IS CLAMPED AGAINST, WHEN I RUN THE ENGINE WITH NO BAR AND CHAIN...
Dec 21, 2010 | Garden
The chain stopped oiling how do i repair this
Need to determine if the oil is really bad or not. The oil is pumped out of a hole on the back side of the bar. It pumps the oil into a hole in the bar where the chain catches the oil and carries it around the bar. Sometimes that hole can get clogged up with sawdust and won't let the oil into the bar. You can take the bar and chain completely off if you like. Clean it will then with the bar off start the chainsaw and see if you're getting oil of the injector. Most times this will fix the problem. If this doesn't fix the problem clean out the oil tank and clean the nozzle to the injector.
Nov 23, 2009 | Electrolux Poulan Bar & Chain Oil 12 each
On a 1998 chevy blazer zrz 4 x 4 i get the code of p0452 evap emmission control system pressure sensor low what does this mean? how do i solve this problem? also, when i push in the clutch it makes a...
P0452 indicates a low voltage signal from the fuel tank pressure sensor, which converts fuel tank pressure into a voltage signal sent to the ECM.
Evaporative Emission Control System Pressure Sensor Low Input indicates a low voltage problem in the Fuel Tank Pressure Sensor (FTPS). What the fuel FTP sensor does is convert fuel tank absolute pressure into electrical signals and inputs the signal to the ECM/PCM, (Computer). First thing to do is make sure the gas cap is good and tightened properly. Given the gas cap's age, you may just want to replace it as the seal may be dry and leaking which would give you a low pressure signal. Then check the vacuum lines and wiring at the FTPS (Location-Fuel Tank) to be sure they are good, clean and tight. Barring a wiring problem it can be a bad FTPS.
Regarding the noise from clutch, it seems to be a bearing issue or the clutch plate/pad might have worn.
Hope i helped.
Thanks for using ' Fixya ' and have a nice day!!
Jul 11, 2009 | Chevrolet Blazer Cars & Trucks
I cant get oil to the chain on my husqvarna 345.
You may have a problem with blockage in the oiler system somewhere. Try emptying out all of the bar oil and swishing some gas around in the bar oil tank to clean it out. This will work some of the time. Sometimes you have to take the oiler off and blow thru the lines into the tank,( make sure the oil fill cap is off) and blow into the oil tank out thru the line to clear out any debris . The adjustment for the oil pump should be on the bottom of the saw. Here is the manual with the procedure on page 32 of the manual. Hope that helps you.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140235-95.pdf
Jun 12, 2009 | Husqvarna Forest & Garden No.967012396 345...
Stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Apr 14, 2009 | Garden
Ryobi 40 cc bar oiler not working
Hi and welcome to FixYa,
Areas/components to check/clean and ensure no clogging:
  • oil filter
  • oil line
  • oiler pump
  • worm gear drive
  • bar
  • oil hose/feeder to the bar.
For the exploded parts diagram of a PCN4040, pls click here.
Good luck and thank you for using FixYa.
Feb 16, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Will Digital Converter Plug in to 1993 Sony Watchman?
Yes,you can use the audio/video input jack on the TV with a connecting wire (mini-plug on one end,RCA plugs on the other) hook other end to output on converter box.
Jan 29, 2009 | Sony Watchman FDL-250T 2.5 in. Handheld...
Tv reception on handheld Sony Watchman in Feb 2009
The old Watchmans are analog. If plugged into a digital cable/dish system it will scan in UHF and find the working channel than can be conrolled by your digital remote control. As far as taking it out on its own and working off the external antenna...those days will be over. Sony will have to manufacture digital Watchmans.
Jul 07, 2008 | Sony Watchman FDL-22 2.2 in. Television
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
