Question about Activision Guitar Hero Wireless Les Paul Guitar for PlayStation 3
Ps3 dongle universal - Activision Guitar Hero Wireless Les Paul Guitar for PlayStation 3
I Got an speedlink SL-4451-SBK for ps3 and it wont connect
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Dec 02, 2012 | Video Game Consoles & Games
I have a madcatz call of duty black ops controll, it charges when i connect it but wont connect to my ps3? help me!
You need to sync your controller with the ps3, put the USB dongle into one of the available slots on the ps3 - exactly where you would normally connect a wired controller on the front. Now switch on your ps3, the dongle will connect, now put your USB cable into the black ops controller and switch on - your 4 lights should be flashing on the controller. Now press connect on the USB dongle, your controller should now sync to the ps3 and hopefully will show as controller No 1. Remove the USB cable and play wireless.
Jul 13, 2012 | Mad Catz Call of Duty Black Ops...
Ps3 afterglow dongle not working?
Chilly100 do u have to open the controller to access the reset button??
Mar 31, 2012 | Video Game Consoles & Games
Gioteck vx1 wireless controller will not pair up to my ps3
Jan 04, 2012 | Video Game Consoles & Games
When my son tries to play his guitar all the lights are flashing on it and we cant figure out how to get it working..
The flashing lights on the controller mean the guitar is not connecting to the wireless usb dongle connected to the PS3.
1. Verify that the wireless box is plugged in firmly to the usb port on the front of the PS3.
2. If that doesn't work, look on the wireless usb dongle for the guitar hero guitar controller. (It should be a black box with the guitar hero logo on it. You will find a small push button on the dongle. (Make sure your PS3 is turned on, though your guitar hero game does not have to be open. It may be a good idea to have the game running, so you can test your guitar or make sure it is really working). Press and hold the button on the wireless usb dongle for a few seconds. Five seconds should be enough. Doing this attempts to re-connect the dongle and the controller. You will know when the connection is good when the red lights on the controller go steady, as well as the LED on the small button you pressed on the wireless usb dongle. If either lights continue to blink, there is a connection problem still.
3. Try changing the batteries in the guitar controller. Weak batteries tend to cause connection issues.
4. Test the wireless usb dongle and controller with another PS3. This will rule out an issue with your PS3 system.
5. If the problem still occurs on another PS3, the wireless dongle may have gone bad. (This does happen rarely.) Replacements are cheap to find on ebay
Jan 11, 2011 | Activision Guitar Hero
I got a drum kit for the ps3 but the drum dongle won't sync with the drums. If i plug another guitar dongle in the drums sync with this and the drums work fine but it's not syncing with the drum hub the...
there are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot.....
Click here to download repair guide
Dec 24, 2010 | Sony Playstation 3 (PS3) Console
Hello i have a,,,cordless mediaboard pro,,, for ps3?
I am running xp/sp3 on a desktop and it works fine with an iogear GBU421T dongle. I tried the cheap noname dongles and they kept hanging and dropping the keyboard so I wouldn't trust those. But this iogear dongle works fine for me. Never drops at all.
May 01, 2010 | Logitech Cordless MediaBoard Pro Keyboard
Hi,how do i connect my orange wireless dongle to my ps3,i do have windows7.
The wireless dongle does not work as a wireless network card or router.
What this dongle does is simply connects wirelessly to the Orange broadband network so your computer can go online.
The PS3 will need to either connect to router or a network card on your computer.
Once your PS3 is connected to the computer, you can then share the network connection through Windows 7.
Thanks,
Pat
Mar 14, 2010 | Computers & Internet
How do i run my ps3 with a usb dongle
you should connect the modem to your notebook, then use the Network Assistant in your OS and share the connection provided by the usb modem .
then the web sharing must be done by a router that should be connect both Playstation and PC.
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
Activision Guitar Hero Wireless Les Paul Guitar for PlayStation 3 Logo
46 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
