Question about Dryers
Concord fans wiring
Series 52pa5 year 2000 serial d0007366, I want to eliminate the electronic board in the bottom and wire directly to the motor. The incoming wires go to a plug which connects to the electronic board. If I cut the plug out how would I connect the loose wires together to operate the fan and the light kit below.
    Genius:
  • 1,617 Answers
Don't think you can do that.
Posted on May 17, 2013
freetek
  • 5568 Answers
SOURCE: neutral (white) wire connection
Use caution when dealing with AC, it can be deadly.
The black wire by accepted standards is the 'hot' wire and will measure (when active) 110-125 volts (in the US) to ground or the white neutral wire in a normal household system.
The white wire may have a couple of volts when measured to an earth ground or any green (or green-yellow) wire which is (by standards) connected to earth ground, often via plumbing pipes in some homes, or a visible or buried grounding rod driven several feet into the earth.
The black (hot) wire is the one customarily 'switched.'
I would highly recommend you have a qualified electrician reconnect the strayed wires to protect yourself and the fan.
Posted on Jul 09, 2008
SOURCE: I have a Hunter Fan purchased in 2003. It has the
Called Tech Support
Posted on Oct 08, 2009
  • 127 Answers
SOURCE: Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Posted on Jan 06, 2010
  • 351 Answers
SOURCE: Trying to connect a ceiling fan light kit.
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
Posted on Jun 01, 2010
RyanFanMan
  • 342 Answers
SOURCE: i was trying to install a fan control switch on my
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Posted on Jan 01, 2011
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
How do I find light kit to work with my Concord ceiling fan? Concord Series 5200-4/3 Serial # HC1131
Have you searched the Internet? You can find just about anything concerning just about anything on it. If not, try one of the home improvement stores or maybe you have a store near where you live that carries Concord fans.
If none of this results in success, you may be able to find a "universal kit" to install on your fan.
Nov 22, 2014 | Dryers
Brought the GE WR55X10942 Refrigerator Main Control Board, and I am getting ready to install it, it saids to eliminate thermistor wire in pin 2 of J1 connector for any encoder models that starts with a...
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Jul 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Model 11-85862400: Check Lint Screen light blinking and will not start. Cleaned sensor and all bottom inside of dryer. Will not start.
Disconnect power and remove the two screws from the bottom flange of the toe panel then pull the panel down and off the cabinet.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct.
Remove the wires from the terminals of the thermal fuse then join them together and insulate the connection properly.
Reconnect power then press start. Replace the thermal fuse along with the thermistor if the dryer starts. The thermal fuse is wired in series with the motor and if it is blown, power to the motor is terminated and will not run. No dryer function works when the motor doesn't run. The thermal fuse usually blows due to failed thermistor or blocked lint screen or vents. This is the reason the "Check lint screen." message flashes.
Disconnect power, if the dryer still doesn't start, then remove the top panel and check if the belt is still on. The belt activates the belt switch which is also wired in series with the motor and the thermal fuse. The motor will therefore not run if the drive belt is off and the belt switch is not activated.
Check the wire connections on the electronic control board. The electronic control board has indeed failed and needs to be replaced as what the Sears repairman said. The electronic control board is part number 8546219 and it costs about $180.
Feb 11, 2011 | Kenmore Elite HE4 Electric Dryer
3.1 grand cherokee jeep 2001 td ltd boiling over chandged rad ,stat ,pump seems ok any ideas .ok on tickover with pressure cap on or of but when driving for about 30min car boils over and water light comes...
Check out the fan, maybe is not working, about 1 year ago same happened to me, changed many parts but keep getting hot and finally found that the fan had a short circuit and sometimes didnt work.
There is a connector between the fan motor and the fuse box eliminate the connector instead directly join wire to wire
Oct 17, 2010 | 2001 Jeep Grand Cherokee
Model FA1-0013 TYPE SWAN SERIAL # MAY00 VORNADO FAN When you plug it in and turn on the switch it does not work.
The motor has a single-use fuse in the run winding; that may be tripped. Or there could be no power going to the motor. Some of the swans had a power lead that was too short and pulled out of the switch. Take the 5 feet/screws out of the fan and remove the bottom plate. Are any of the wires loose that go to the switch? One power lead goes to the white wire that runsd directly to the motor: is that hooked up? If you need more help, contact me.
cawicks at g mail
Aug 29, 2010 | Vornado Circulating Fan
I have a Concord Series 52PA5, Model HC-1993OS. The fan speed switch has been cut out. I want to wall switch it and only fun fast speed. What color wires do I hook to the 110?
Generally speaking, your blue or black wires are going to be hot. Your white wire is going to be neutral and your green wire is going to be ground.
Aug 21, 2010 | Concord Fans (52MA5WH) 52'' MADISON...
Fan blade barely rotates when turned on high.
there may be a problem with fan motor,but i believe your problem may be the rotory switch that controlls voltage to fan motor,to check this pull knobs off front ,then remove filter from back,there are 4 screws in bottom of case remove these,pull unit out carefully .there are 5 wires conected to unit ,two for fan 2 for on off switch,1 for ground just what wires go were,then disconnect wires from there posts,and pull unit out of box,find the two wires that go fan,snip wires that go to the circiut board leaving enough space to rewire after test get extention cord and snip off to make direct plug to fan to wall connect extention to the two wires from the fan motor and wire nut or tape so no short,pug extention cord into wall outlet if fan runs on a high rpm or max power,then your rotory switch is no good and you can install an external rotory switch on side of unit,if fan does not run any faster then your fan motor needs replaced,let me no if you need more help
Dec 03, 2009 | Ecoquest Living Air Classic Air Purifier
Need a wiring diargam to look at
You won't find a diagram.
You will have series of yellow and white and sometimes gray wires on the outside of the motor housing and often a letter code etched on the housing , indicating the original wiring from years ago, red, blue, yellow, however the newer wiring eliminated those colors.
These wires are almost fool proof as they will align with the longest wire at the furthest point,a center one piggy backed , etc however before starting please post back to advise if you have removed the rewind and or motor and if so, did you disturb the motor wiring inside the motor shroud.
Please post the original problem you opened the vac for as well and I will try to walk you through this
Nov 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Over heating
You can test the fan itself by unplugging the connector to the fan relay and crossing the heavy gauge wires with another peice of heavy gauge wire. The fan should spin right up and you can then eliminate the motor as the problem. You probably have another bad fan relay. And your right about probably wanting to replace the thermostat as well.
Aug 02, 2008 | 2000 Jeep Grand Cherokee
Dryers Logo
Top Dryers Experts
