Question about Radio Communications
Commtel com 215 base scanner
How to reset
2 Suggested Answers
scottbates
  • 31 Answers
SOURCE: Trying to find a battery pack for a Commtel com
model number bp120
Posted on Dec 26, 2014
I'm trying to find the correct battery pack for a Commtel com 214 scanner.Unit says 12v dc.??
The 12vdc refers to the charger you need,
The battrey is a rechargeable internal battery and you just need to find a 12v charger,
ebay "commrel 214 scanner charger" to buy it
if you do need a new battery the model number is bp-120
here is a link to pictures of the battery and EVERYTHING you need to know about the scanner
http://radiopics.com/Commtel/Commtel_COM214.htm
Dec 26, 2014 | Office Equipment & Supplies
What is the dodge caravan 1999 3.0L V6 base van tire and rim sizes?
This information is listed in your owner's manual and on the driver's door post. But in case the placard is missing and you do not have an owner's manual, the OEM size is dependent on the size wheels installed. The correct sizes are:
15" - 215/65-15
16" - 215/65-16
17" - 215/60-17
Sep 20, 2010 | 1999 Dodge Caravan
How to clear all channels and reset them
RESET and INITIALIZE procedures for your scanner can be found on pages 71 and 72 of the factory operating instructions, which you can download and print here:
http://support.radioshack.com/manuals/ome20-496.pdf
Bill B
Sep 12, 2010 | Radio Shack Pro-2096 Base Scanner
HOW DO YOU RESET IT?
Hi!
From your owner's manual (Page 27)
Resetting the Scanner (Clearing all Memories)
To reset the scanner to factory defaults, turn off the scanner. Then, while
holding down 2, 9, and HOLD, turn on the scanner. All scanner memory
contents are erased.
Here's the link to your manual as well:
http://www.uniden.com/pdf/BC340CRSom.pdf
Hope this helps.
Sep 12, 2010 | Uniden BC340CRS Base Scanner
I am trying to find operating instructions for a Commtel-206 scanner.
Your scanner was also marketed as the GRE PSR-244, and it's nearly identical to the Radio Shack PRO-62. I couldn't locate a manual for the Commtel or GRE, but you download/print instructions for the PRO-62 here:
http://support.radioshack.com/support_electronics/16620.htm
Bill B
May 09, 2010 | Radio Communications
MY 2096 BASE SCANNER READS ALL CHANNELS LOCKED AND I CAN'T UN DO IT AND OPERATE NORMAL. HOW DO I CORRECT THIS PROBLEM?
If all else fails, and it sounds like it has, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Jan 24, 2010 | Radio Shack Pro-2096 Base Scanner
Help! lost device code list for COMMTEL CONTROL FREAK REMOTE CONT
codes for grundig , 0331,1211,1221,1231,1241,1251,1261,1271,1281,1301,1311,1321,1331,1341,1351,2541,2551,
2751,2781,2791
hope this helps .
Feb 22, 2009 | One For All URC-3021 Remote Control
Remote Codes for Commtel Control Freak and JVC
0053, 1253, 1923 if those don't work, I have others.
Jan 18, 2009 | JVC RM-C18G-1H Remote Control
Radio Communications Logo
77 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
