Question about Coby Kyros MID7015 Tablet
Repair Center Touch screen damage
    Problem Solver:
  • 11 Answers
Well i have the same problem, my screen is cracked also. I saw on the internert that its cost at least like $20 to get it fixed.
Posted on May 03, 2013
Do i need a lcd and digitizer to fix a cracked screen
What kind of screen is it ,is it Gorilla glass or plastic or what find that out first then ill let you know ,,,good day
Mar 05, 2015 | Nextbook Premium 7 Capacitive Touch...
My 9" tablet's screen has broken where can i repair it. Am in Springs Ekurhuleni South Africa. My name is Pumeza. my email is pumeza.matiyela@implats.co.za
It's at all not worth repairing this old device. the screen can cost more than half the cost of a new tablet, unless the crack is only on the touch panel which is the clear glass mounted directly above the screen. In most tablets, both must be replaced because dismantling the screen or touch panel will usually damage the other. Better to buy a new tablet.
Feb 20, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
Broke my screen, still turns on and shows picture but touchscreen no longer responds. Is there a repair for this type of discrepancy?
Screen repair is a common fix. Check the yellow pages for a repair person or service. Depending on the damage the repair may not be worth the phone.
Feb 09, 2015 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
SCREEN TOUCH NOT WORKING WHAT CAN I DO ?
1.- Run Lenovo diagnostics and look out for hardware errors.
2.- Reinstall screen and input drivers.
3.- Take it to a lenovo repair center.
Nov 09, 2014 | Lenovo Yoga 10 10.1 inch Tablet with 16GB...
My nexus 10 tablet turns on but screen won't display anything, even though you hear it working and active when you touch the screen it just doesn't visually display anything?
Definitely, it has a problem with the LCD. Well, if that was already opened by the service center maybe, the reassembly of the device is not proper (maybe you were right, you got screwed by negligent service repair guy). But let me ask you, does that repair center an authorize repair center of Samsung devices in your place? Try to go to an authorize repair center, so you won't worry much about your tablet. That's my only advice 'coz I think it will be the best for your tablet and for you, too. 'Coz, if I will advice you to pry your tablet and go into technical stuff you might probably lost and your problem will get worst. But if you have the guts to do it, just use a precision tools and check if the LCD connections is properly connected by those repairmen you have deal with. And it is much better if you have a tablet lcd tester. But I'm pretty sure you wont try to exert an effort to buy a tester since you wont use it much. So, as I've said try to go to a certified Samsung service center.
Mar 10, 2014 | Tablets & eReaders
Ipad 1 touch screen unresponsive
Is the screen cracked or damaged in any way? You may need to have the digitizer glass replaced. The digitizer is the part hat actually senses the touch feature on your tablet. Exposure to moisture is also a question that should be considered.. If it was exposed to liquid, this could also cause the problems you are having. Unfortunately the success rate of repair of liquid damage is very low so hopefully this is not the case..
Feb 15, 2014 | Apple iPad Tablets & eReaders
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Supersonic 7" Touch Screen MID Tablet
Drop the tablet
The screen probably will have to be replaced but the fall may have caused internal damage so that even with a new screen the tablet may not work without further repair.
Dec 30, 2013 | Supersonic SC-91JB 9-inch Android 4.1...
KOCASO Model:M750 Pink
These capacitive touch screens are very sensitive; most likely you damaged it [more than you think] when you dropped it.
If your within the warranty period or purchased an extended warranty that includes replacing the screen when damaged, you should call tech support to get an RMA [return merchandise authorization] number to have a warranty repair done. If it is out of warranty, you will incur the repair costs- that is, labor and materials.
Nov 27, 2013 | Kocaso M752B Dual Camera Android 4.0 OS 7"...
Touch Screen Broken
Hi I am Vortash yes you can but to be honest I wouldst advise it .. touch screens are expensive and very easy to damage especially during installation .. an over fastened screw .. a wire underneath it ... damaged ribbon insert.. it is a job for an expert and don't forget if you have it repaired by a service engineer it will have a warranty for a while ..? The other thing to think about is if it was broken accidentally then it may be covered under a household insurance and you can claim for the repair . Regards Vortash
Apr 06, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Coby Kyros MID7015 Tablet Logo
144 people viewed this question
Top Coby Tablets & eReaders Experts
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
