Question about La Crosse Measuring Tools & Sensors
9640itc I have 3 uts one is still working perfect. The other 2, the outside temperature show --. I tried replaced batteries on both and still not working. Time and inside temp still work
SOURCE: Outside Weather Not Displaying
Restart as if from new ie as if it is being taken out of the box
Posted on Jan 31, 2008
SOURCE: resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Posted on Jul 09, 2008
SOURCE: Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Posted on Jan 18, 2009
  • 10 Answers
SOURCE: skyscan digital wall clock just quit showing outside temperature
you probably need to 'pair' the outdoor sensor with the main base: look for a 'channel' button, as these units usually can get information from several sensors and differentiate them by a channel number.
Posted on May 10, 2010
  • 17 Answers
SOURCE: outside temp does not read new batterys in both
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Posted on Oct 21, 2010
Why is indoor display not showing outside temperatures?
If the condition comes and goes, the outside unit may be exposed to extreme temperatures or the batteries may be too weak. If the condition occurred after battery replacement, remove all batteries then reinstall the outside battery and wait for it to "initialize" and begin sending data. ReInstall the inside battery and you should see the outside temperature displayed.
Feb 13, 2016 | Measuring Tools & Sensors
Model 00822A2. Why doesn't inside unit show outside temperature?
If you tried removing and replacing batteries, you should bear in mind that all batteries should be removed to "reset" the station then batteries should be installed in the outside sender first and time allowed for it to begin transmitting temperature. Next, batteries should be installed in the receiver and you should begin to read outside temperature.
Nov 24, 2015 | Acu-Rite Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
My atomic clock won't show the outside temperature and I can't get it set for regular time, it only shows military time. How do I fix these two problems?
Hi
If you have lost the outside temperature on the clock display then do the following:-
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappears.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
Also check the link bellow:-
http://www.ehow.com/how_4597931_set-atomic-clock.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 31, 2011 | Office Equipment & Supplies
Outside temp. display
if it is wireless then check the sender unit
check the battery
severe cold weather can be hard on batteries
Jan 02, 2010 | La Crosse Technology WT-2171-UCS Digital...
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Remote Sensor
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Measuring Tools & Sensors Logo
65 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
john milligan
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
