A3MX235ATW-BK-1-A-S-20120907-01259-B PHOTOCOPIER IS DISPLAYING F2
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
How do I clear F2 and H4 on Sharp photocopier
F2 means wrong cartridge installed, could be a bad cartridge. H4 is a low fuser temp error. try resetting by pressing "#","interrupt","C","interrupt. then press"1","4","start". then turn off/on and see if it clears. if not you will need a tech.
Nov 12, 2009 | Televison & Video
Call for service
There is a problem with the Bk Toner supply.... check the End Seal was removed on the Cart, if not that, then call a Tech.
OR
put the an old, used bk toner cartridge back in and restarted the printer. Once all the codes cleared, removed the old bk toner and put back the original bk toner u had removed.
that should fix
May 13, 2009 | Sharp MX-3501N All-In-One Printer
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Car raidio
speakers: L/F - OG/LG [+] LB/WH [-]
L/R - GY/LB [+] TN/YE [-[
R/R- OR/RD[+] BN/PK [-]
R/F- WH/LG [+] DG/OR [-]
WH/YE HOT f2 20 amp fuse box
BK/PK HOT VPWR
RD/BK illumination
RD/LB Hot in start f2 5 amp fuse box
BK ground
BK/LB ground
BK/OG ground
as far as I know there isn't a "remote" wire unless you are dealing with steering wheel switches
Hope this helps!!
Feb 02, 2009 | 2002 Ford Explorer
29 people viewed this question
jasbo
jasbo
