Question about AT&T Motorola c168i Pay-As-You-Go Cell Phone - Lustrous Silver
Proxima screen displays red
    New Friend:
Please help me to unlock my Motorola C168i at&t mobile
IMEI No:0112190065856
Posted on Sep 23, 2013
I have a Samsung SL620 and the LCD screen is red when its on but the display information is readable and correct. What's wrong with it?
if it is ok for take a picture? if lcd screen is red and picture is not clear, probably it is the problem of camera sensor. You need change it.
Nov 30, 2012 | Samsung SL620 Digital Camera
Red line on screen above red line screen is distorted below line and it is fine!!
Could be a bad display. If that's the case buy a new TV because the displays are usually more than a new TV itself. God I miss CRT's...
Nov 04, 2012 | Televison & Video
The pc is ok and log in normal, but the screen is red. Is this the card or can I fix it
This problem is typically a monitor problem. Firstly check all the connecting pins of the monitor vga cable where it plugs into your display card. Sometimes these pins are either bent or pushed into the plug and do not make proper contact with the card pin socket.
The quickest way to determine the fault would be to plug in another monitor & see if you get the same red screen. If the other screen also shows up red, you can safely rule out a faulty screen & just replace your display card. My guess is that the other screen will display correctly & you will have to repair or replace your own screen.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Mar 04, 2011 | LG Studioworks 99T Monitor
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
Screen becomes red sometimes.
Try reinstalling the Display adapter from the recovery partion. Start>All Programs>Gateway>Restore Application & Drivers> Select the appropriate driver. Also update the display driverfrom http:\\support.gateway.com
Mar 12, 2010 | Gateway MD2614u Notebook
RU-42PZ71 displays red lines
No, you will need to call an engineer to check the display, this sounds like a fault either with the main board or very possibly (and most likely) a fault with the screen which would mean replacing the screen
Dec 18, 2009 | LG RU-42PZ71 42 in. EDTV-Ready Plasma...
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a red strip about a a wide all the way down the screen
It sounds as if your display is going bad. If put a little pressure on the screen and the red strip warps it is probably your liquid crystal display in the screen itself.
Apr 03, 2009 | Dell Inspiron 1501 Notebook
Error on the display -
I had the exact same issue with one of these printers. 83C00020 on the display with a blue background. printer will not power off.
Try this - Press and hold the OK button then press the power button to reset the printer .
I did this and it powerd on ok and is now working fine.
Apr 18, 2008 | HP Photosmart 2575 All-In-One InkJet...
AMILO M1451G display
if you can notice this problem in the BIOS then the problem is with the Display adapter .. if you newly bought your computer i suggest you send it back
Dec 29, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
AT&T Motorola c168i Pay-As-You-Go Cell Phone - Lustrous Silver Logo
19 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
