Question about Briggs & Stratton Garden
21 hp ohv
Engine changes RPM back and forth. can see governor move up and down
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
Carb needs to be rebuilt
Posted on Jun 07, 2014
5 Suggested Answers
  • 143 Answers
SOURCE: Poulen mower B&S 4.5hp engine "hunts" up and down
The diaphram between the carb and the fuel tank needs renewing.
Posted on Jun 13, 2009
mowerman1857
  • 389 Answers
SOURCE: mower stops when you pull the throttle back to
If you are pulling it all the way back, that is the STOP position and is normal. If you are only pulling it part way back, then your idle is set too slow
Posted on Sep 15, 2009
  • 16 Answers
SOURCE: Have B&S 4hp lawn mower (20
If its the 4hp classic type Briggs engine with the red primer bulb on the side of the carb then it needs a new diaphragm. Very cheap and simple repair.
see this link for a good picture + price
http://shop.jungle-busters.co.uk/epages/es122164.sf/en_GB/?ObjectPath=/Shops/es122164/Products/795083
Posted on Oct 13, 2009
  • 100 Answers
SOURCE: i cannot find any decal that tells me the the
if its a briggs motor it is usually stamped in metal cowl either on front above sparkplug or side above muffler
Posted on Aug 14, 2010
How to adjust governor controls on 13 hp techumseh engine fitted on 45 in cub cadet snowblower
At the base of the governor arm is a screw, loosen the screw and move the arm approx, 90 degrees. Allow the engine to come to a steady idle then tighten, the move the throttle up and check for a smooth exceleration. it may take a little back and forth but this should get you there.
Feb 17, 2015 | Cub Cadet Garden
How do you control idle
This sounds like a governor problem, try moving the governor back and forth,l
Apr 17, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Toro briggs OHV runs too fast
throttle spring could be broken stretched or missing
Nov 14, 2012 | Toro Lawn Mower With Toro Power Tools
Briggs/Stratton 23 hp vtwin max rpm and how to adjust it.
If you bend the tab down a little on the larger of the two springs, in the direction of adding tension, it will raise rpm. Be careful not to bend too much or your engine will not fully return to idle.
Oct 08, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How to adjust a fuel governor for a 3750 watt coleman generator
With parts list in hand, look at reference #21 governor arm and reference 89/90 adjustment screw. This adjustment will increase decrease engine speed. I would use a meter with hz setting to set engine speed to achieve 60 cycles. Sixty cycles on the meter would indicate that the engine is turning 3600 rpm which is max. If all working correctly, voltage should be around 120v at 3600 rpm and 60 cycles. Good luck
Aug 02, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
Craftmans 10 hp ohv engine generator it starts and wont idle it runs wide open..is it a bad governor?
Make sure the throttle shaft is not stuck in the wide open position. You may also make sure the throttle plate is attached to the shaft, these have been know to come loose and if the shaft moves the plate does not move with it. You may have an internal governor problem, but it is best to eliminate all outside possibilities before pulling the engine down. There is also a "static" adjustment that can be made to the governor but you may want to see a service manual to perform that operation.
Feb 16, 2011 | Garden
The govenor rod cannot be adjusted. The springs are intact. Motor revs up but will not idle down. It is 23 HP.
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Rpm maxes out and I can't bring it down
check that throttle linkage is ok and free, check that throttle plate is free to move and not jammed - check that srew in the throttle plate is not allowing plate to restrict and jamb throttle
check the governor springs and links are in the correct places and are free to move , check that governor is working ?
if its not migght be governor is adjusted wrong or slipped
or its flown to peices
if unit is ohv model have seen the the ocilating balancer
torque link rod break and cause a engine to go to full throttle
as sson aas the engine was started
please let me know model and type numbers off the engine in question and its make ie briggs etc
and will try help further
cheers paul
Aug 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
18 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
