Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Row of characters stopped working
The keyboard worked fine. Then the middle row of characters ('a, s, d, f, g...etc.') stopped working. The final two characters on the right (:; and '" still work). The other keys on that line mentioned above don't advance the cursor. They don't seem connected to the computer at all. The rest is still working fine.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Sometimes the ribbon connector becomes disconnected from the connector on the motherboard. You can fix it by removing the connector inserting a slim piece of plastic and reinserting the connector.
Posted on Nov 10, 2013
  • 4 Answers
SOURCE: cursor skips back into sentece or paragraph
Usually it is just from your hand/thumb touching the touchpad and registering as a single-click causing the cursor to jump back. This is a well known issue with the MacAir due to size/design of the machine and the sensitivity of the trackpad. Many people have found it to be resolved by turning off the "touch to tap" feature, however it is annoying when you need that. Hope this helps you! Happy Hollidays!
-Joshua Childs
Posted on Dec 26, 2008
Joed911
  • 4338 Answers
SOURCE: the 2,w, s. and x keys on my ibook g3 laptop do not work
check this link for tips on how to fix it:
http://geektechnique.org/projectlab/160/zen-and-the-art-of-ibook-keyboard-maintenance
or purchase a new keyboard:
http://www.google.com/products?q=keyboard+iBook+G3&hl=en
If you need instructions on how to replace the keyboard, let me know.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Jo
Posted on Jun 16, 2009
  • 166 Answers
SOURCE: some keys won't work; delete, tab, spacebar, pg
THE SOLUTION IS ONLY TO CHANGE THE KEYBOARD OF YOUR NOTE BOOK.
DONT FORGET TO VOTE
Posted on Sep 14, 2009
  • 13 Answers
SOURCE: The right shift key does not work as well as a few
Hi there , this might be the ribbon cable connecting the keyboard to the laptop , lay the screen flat , look at the left hand side of the lap top , there is a strip you can lift up , where the power switch is. lift the strip up , you will now see the two screws holding the keyboard down, unscrew them , slide the keyboard up slowly and lift , gentaly you will now see the small riben cable, lift the small black catch , then reseat the cable , push the catch back, and reseat the keyboard. now retry the keyboard ...
Posted on Nov 22, 2010
SOURCE: my apple 13-inch MACBOOK got water damage, after
@ devilzback_1:
I just spilled water on my Macbook Pro and am having the exact same problem you experienced. Did you ever find a solution? FYI I ready thru the 2 solutions here but am not tech savvy.
Thanks in advance for any help.
Posted on Feb 26, 2012
Apple A1242 keyboard
you need to replace it water got in to it. or you can try putting your macbook upside down for a few days to keep it from going in to the main board. i did that with mine.
May 02, 2013 | Computers & Internet
My 4th row of keypad is not working except g,h,',caps
Try removing Keyboard connector an reseating it. (4420s - Some scews under battery and possibly 1 near rear of each hinge - remove. Flip unit over and slide Speaker grill panel toward front of unit. There should then be a few screws that hold the keyboard at the top edge 2 or 3. Remove and you should see the connector. )
If this doesn't work you have faulty keyboard.
Jul 07, 2012 | HEWLETT-PACKARD ProBook 4420s Notebook
How on earth can I get my computer, to stop writing numbers with every letter in the middle row of my keyboard? l9ik8e it's2 d3oing5 now a1s2d3f4g5h6j7k8l9. Pretty sure it's not a numlock thin
what is going on with your keyboard is it is in the Fn mode that is usually used for math. You need to find out what is the correct way to reverse this mode, sometimes i find it easy to google the fn key functions and you put in what type of computer you have and then you usualy will get your answer. There is nothing wrong with the keyboard just the mode.
Jan 30, 2012 | Apple Computers & Internet
Keyboard double letters showing
there is short in the data cable
may be some liquids spill inside it
you have to clean it and if this fail may the keyboard controller on the mother board is corrupted then you have to use external K.B or change the Mother Board
shadi
dont forget to rate my solution
Jan 24, 2010 | Dell 0Y3740 Keyboard
Character Set is all messed/mixed up
there is a little metal pin on the opposite side of the wheel , line the dot to the arrow and re insert.
Jan 15, 2009 | Brother ML-100 Typewriter
Keyboard will not accept characters. Goes thunk.
Try using an external keyboard in order to get the machine up and running. Then do a system restore to a point where you know the keyboard was functioning correctly. If that doesn't work then try uninstalling the keyboard drivers and do a hardware search. It will automatically pick up the keyboard and reinstall the drivers. If it still doesn't work, then the keyboard needs replacing.
Jun 17, 2008 | Dell Inspiron 1501 Notebook
Keyboard data entry
Sounds like a classic problem for a driver/firmware update. get an update here before trying anything else- http://www.palm.com/us/support/downloads/tungstenc/tungstenc_update_30.html If it still doesn't solve it you might need to format it and reinstall everything from scratch. Good luck
Apr 22, 2006 | Palm Tungsten C Handheld
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
104 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
