Question about Sharp XE-A203 Cash register
After loosing electricity, register will not come on.
Our shop lost electricity and now it will not power up. Is there a reset or a fuse I need to check?
Circuit protect fuse
It sounds to me like internal fuse on the power board of the TV. It is usualy a glass cilinder with metal caps on both sides, could be found in any electrical shop or even car-part shops because old cars used same fuses some time ago
Aug 04, 2017 | Acer Computers & Internet
What do I do if the battery fails on my register
Before you reprogram replace the battery then do an initial reset
Sep 06, 2014 | Samsung SAM4s ER-650 Cash Register
Oven light blew and now no power to the oven.
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Nov 25, 2013 | Zanussi ZBF360 Electric Single Oven
Losing all power
Check your main ground attached to the engine block for being loose or not clean...
Oct 11, 2013 | Chevrolet S 10 Cars & Trucks
I have a 1995 ford mustang v6 3.8 liter automatic, situation- pulled up to a store and got something to drink. went back to the car turn the key over and heard a click and lost all electrical power, the...
check your fuses. I expect its one of you main uses located under he hood. You also have another fuse box under the dash in the drivers side footwell. Check all the fuses and if any are broken and replace if necessary. Further electrical problems will likely need to be diagnosed by a shop.
cheers
May 20, 2010 | 1996 Ford Mustang
Cd player stopped working out of nowhere .. bad fuse? need the diagram for the interior fuse box lost the panel .. 2000 hyundai sonata
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Oct 23, 2009 | 2001 Hyundai Sonata
No electrical power to the kill switch on my
Hi and welcome to FixYa,
Initially, check the fuse and fuse holder in the fuse box under the seat. Pay Particular attention to the middle fuse. In some instances, the fuse itself maybe good but the holder is loose or corroded. Do the same for the ignition switch.
Good luck an thank you for asking FixYa.
Jul 31, 2009 | Suzuki RF 900 R Motorcycles
I have a 2000 Ford Windstar. While driving the other day I lost all electrical power. Nothing would work and engine cut off. After sitting for a brief time the van cranked back up and I drove it home. ...
Most probably...a loose electrical connection. Since you mentioned that the electrical power and the engine got cut off and after sitting for a brief of time, the van cranked back up. You need to check the wiring to see if there's any loose connection.
Here, I provided you the link where you can download the wiring diagram for your 2000 Ford Windstar:
http://www.installdr.com/InstallDocs/FLM/PDF/356021.pdf
This diagram (manual) will help you trace the problem.
Have a great day!
Jun 06, 2009 | 2003 Ford Windstar
Panasonic PV-GS15
there is no fuse of such sort that can be replaced, try pressing the "reset" button with charged battery attached, maybe it'll help
Aug 22, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
Sharp XE-A203 Cash register Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
