Question about Kenmore Heating & Cooling
How much should my air conditioner be tilted in the window
No water is coming out the back is that normal
  • Bonnie Lucas May 06, 2013
    I had someone come look at it a neighbor, they said it would only drain outside if it was humid out. There is some water in the back of unit not draining out said it was normal, hope so!! Thanks everyone as you can tell I don't know too much about these things may need your help again
    Top Expert:
  • Kenmore Master
  • 39,415 Answers
Window air conditioners generally should be mounted with a slight downward tilt toward the outside. This allows condensate to drain outside rather than inside.
Posted on May 02, 2013
  • 3074 Answers
SOURCE: White smoke coming from vent in room air conditioner
it sounds like it was humid which is normal for the cool air to mist, it will happen in your automobile ,also
Posted on Jul 24, 2010
  • 50 Answers
SOURCE: water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Posted on Jul 22, 2010
  • 193 Answers
SOURCE: water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Posted on Aug 18, 2009
gtmerkley
  • 190 Answers
SOURCE: I have a Maytag window air conditioner that is leaking out front
The unit has to lean backward to let the water run out. It sounds like it is too level or leaning forward too much. There should be an adjusting screw in back that you can lower and it should work fine.
Posted on Jun 27, 2009
shastalaker7
  • 1515 Answers
SOURCE: I am turning on my window air conditioner for the
Hi, what is going on is the unit is working good so you will have condensation running down the front of the indoor coil. You will have a trough at the bottom that has collected dirt over the winter and has clogged up the drain. Some window units have a small supple clear hose attached to one end of the coil that may be plugged up, or this unit has what we call weep holes around it starting at the inside edges on each corner and around the out side. Go outdoors and look and see if you see a hose or very small holes that are plugged up. If the hose/if there is one, try and blow it out. What is happening, is the blade from the fan motor is picking up the water and slinging it into the home. Yes, you can solve this once you find how it drains and where it drains. Take a good strong light inside to check the front and see if indeed there is a hose. Keep me posted on this and I hope that I have led you in the right direction to solve this, and I am sure I have. Please let me know.
Sincerely,
Shastalater7
Posted on May 13, 2010
I just purchased The same air conditioner..it it continues to leak,the water has destroyed my carpet...is there a specific way I am suppose to drain it...I purchased it on Craigslist
Without more information you are out of luck on a complete answer. Normally a window AC (I am assuming a window unit) needs to be tilted a bit to the back so the water will run outside not inside. With two units doing that I am fairly confident that by tilting it to the back just enough for the water to go to the back your problems will be solved but about the carpet get a professional to clean it. These links may help;
DIY Air Conditioner Repair
How to Install an Air Conditioner Rochester Heating Air Conditioning...
http://www.garagejournal.com/forum/showthread.php?t=152192
Air Conditioning Installation Guide DoItYourself com
May 29, 2016 | Heating & Cooling
How do I drain the water from my LG portable air conditioner (LP1010SNR)
Lift up the window securing the AC, and CAREFULLY tilt back the unit. The water lays towards the back of the A/C under the fan.
Apr 17, 2012 | LG Heating & Cooling
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Water is dripping into the house from the brand new air conditioner
Make sure the window unit is tilted back. If its not tilted back in the window, it will drain out the front.
Jun 20, 2011 | Haier HWR08XC7 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
When the airconditioner is on cool.Water comes from the airconditioner inside and dripping on the floor.
If it's a car air conditioner, your condensate drain line is clogged. If it's a home window unit, it needs to be tilted outward more. The downward tilt should be no less than 1/4" per foot. If your unit is 18" from the window to the back of the unit, the back should be 3/8" lower that at the window....minimum.
May 14, 2011 | Mitsubishi Heating & Cooling
Carpet wet under window air con.
The air conditioner needs to be "tilted" or "pitched" to the rear. By this I mean the back (outside) should be slightly lower than the front (inside). This will allow the water to run toward the back of the unit, and drip on the ground instead of inside the house - on the floor. The A/C unit must not be level or tilted into the room (front even with or lower than the rear).
This water is the result of condensation that is created when the warm room air is drawn through the much cooler coil & fins inside the unit and is completely normal. The more humid the air inside is, the more condensation will form, and drain away.
Jul 15, 2010 | Maytag M7X05F2B Air Conditioner
GE Zoneline 2100 Air Conditioner won't drain condensed water
POSITION IN WINDOW SLIGHTLY TILTED BACK, IF ITS CLEAN!! IF NOT BEEN CLEANED AND I MEAN DISSASSEMBLED AND REALLY CLEANED OUT ITS NOT GONNA HELP TO TILT IT MUCH AS THE PASSAGES TO THE REAR CONDENSER COIL ARE CLOGGED, THE CONDENSER IS HOT AND EVAPORATES IT NORMALLY IS ALL IS CLEAN
Aug 23, 2009 | Heating & Cooling
Window air conditioner..
It is normal there is a small hole for the water to escape just make sure that when you mounted it you tilted it down a small amount at the back so it can drip out
Jul 22, 2008 | Heating & Cooling
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
