Question about Refrigerators
I have a Kenmore Fridge Model 596-729-12200
The bottom crisper drawers have started freezing everything I put into them. Can you tell me how to fix this problem? I have tried lowering the temp for the fridge but that does not seem to help. I have also adjusted the humidity level on the drawers but that did not help either.
  • Refrigerators Master
  • 4,654 Answers
I have a Kenmore Fridge Model 596-729-12200  - fb4dfaa6-7995-4ceb-a384-cb74f4ab1f6a.jpgThe fresh food section has a 67003410 Damper that has a thermostat probe that senses the fresh food section temperatures and then regulates the fresh food section cold air from freezer by opening and closing to maintain a set temperature. If defective the damper may remain closed or remain closed. You can test the damper by removing and placing the temperature probe into a glass filled with ice and no water. The damper should close in the ice and open when not in the ice. I will be here to answer any questions you have, Thanks Sea Breeze
Posted on May 02, 2013
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
tech master
  • 120 Answers
SOURCE: crisper drawer freezes veggies
need more info what brand model and is it a side by side or top mount ? more info will be helpful
Posted on Oct 15, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Posted on Nov 26, 2008
  • 27 Answers
SOURCE: Vegetables keep freezing in the fridge crispers
You have to heat the coil in the back of the fridge. Take everything out and open up the back, then take a hair dryer and heat the coil. After doing this, adjust the heat settings on the freezer.
Posted on Nov 19, 2009
  • 1218 Answers
SOURCE: Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Posted on Dec 04, 2009
Why is everything in the crisper drawers freezing?
Crisper draws are at bottom of fridge, cold air collects at the bottom and warmer air rises. Turn thermostat dial down, mine is set on 2 out of 6 and every thing stays fresh and doesn't freeze. In very hot weather I do sometimes turn it up to 3.
Dec 03, 2016 | Refrigerators
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Nov 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Nov 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Crisper drawer freezes veggies
Sep 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore elite fridge crisper drawer freezing stuff
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water from dispenser
I could not locate any white tank where the water comes to/from. There is only a clear plastic water line behind the crisper drawers, that is coiled up and goes up to the water filter at the top on one end, and down through the bottom of the fridge on the other. The coiled line seemed like perhaps it was frozen, so I took a hair dryer to that but it didn't help. I also tried removing the cardboard cover in the bottom back of the fridge, to see if perhaps the white tank was back there, but it was only
more line, which goes towards the front of the fridge, where it goes up into the corner of the door.
Jan 05, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
