Question about Mitsubishi WD65737 65" DLP TV
No color, have changed lamp, I have tried the color bar also
Why is my picture color distored color?????????
Your color is distorted because your color wheel is probably going bad. Try resetting all the picture values first. Sometimes they need to go back to normal when the lamp is changed. Lamps only provide white light and have no bearing on colors unless they are very dim. Also check your cables. a loose or bad cable can cause this as well. Lastly make sure your new lamp is made by Osram or Philips. knock offs wont work.
Feb 21, 2015 | Mitsubishi WD Televison & Video
My mitsubishi wd82738 starts normally green light flashes and then stays on,i get sound and blurred bars that are barely visible
Probably a lamp problem. They aren't very expensive and relatively easy to replace. If not the lamp, possibly the color wheel. If it makes a high pitched sound from time to time, it's definitely the color wheel. Good luck
Aug 26, 2014 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
Tv has "jail bars" effect..lamp is new but watching is like watching it through jail bars..a series of vertical black lines
You may have a color wheel that is losing its speed. Replacing the color wheel is tedious work and somewhat costly $100 to $130. Good Luck and thanks for asking!
Jul 04, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Lamp light on front of tv stays on, it is amber in color
Hi,do you mean tv is showing an amber picture? If you do,it could be an issue with the color wheel or dmd board.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Mitsubishi WD-52525 52" Rear Projection...
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 06, 2009 | Toshiba TDP-S20U Multimedia Projector
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Jun 30, 2008 | Televison & Video
Colored bars across page
I would try changing the ink cartridges and if you don't have a new set at least take out the ones you have and reseat. Also check Epson's site for new drivers. Try printing from a different program.
Mar 28, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Mitsubishi WD65737 65" DLP TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
