Question about Intermatic & Indoor/Outdoor Rain Tight Timer
My et103c will not manually or electronically turn off my pool pump.
  • Intermatic Master
  • 5,245 Answers
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
Unknown if this is new installation, or old installation that stopped working.
Check battery. The timer requires a battery. Located below the buttons.
ET103C digital electronic timer is discontinued but some folks still sell on ebay... selling possibly used timer. Timer has 1 year limited warranty from date of manufacture.
Timer has error code messages... if you receive no error code, then battery could be problem.
Line noise can cause timer not to function, such as fluorescent lights on same circuit etc.
ET103C clock mechanism is 120Volt 60 Hz. If pump and circuit are 208-240Volt, or 277V etc then this timer is not best choice unless neutral wire is available..
Add a comment and describe situation in more detail.
Posted on May 03, 2013
I smell a little natural gas when turning on pump, is this normal? pump doesn't show any problems codes.
never heard of a gas powered pool pump. if you meant when turning on the heater, this might indicate a small leak at the control valve.
Jul 04, 2014 | Hayward H-series Electronic Gas Pool...
Check voltage at clock.
ET103C is discontinued digital electronic timer.
Copy following link to idcentify timer:
Always check battery first... located under the buttons and above the wiring terminals.in pull-out tray. Use reset button to reset after battery change.
Test for 120Volt across terminals 1 and 2 should show at least 80% rated voltage,
Add comment and say if this is freshly installed timer, of if timer worked before.
Also add if circuit is 240Volt, and what size breaker, wire and HP motor
May 02, 2013 | Intermatic ET103C Electronic Timer
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
Turn heater for pool while pump in on, everything is fine, pool heats then when timer stops pumping, the heater will stop but the digital temp climbs,on display and eventually goes on the display...
When the system shuts down the water inside the heater collects residual heat in the heater. For most systems that have intermatic timers (yellow dial) you can get a fireman's switch kit that will shut the heater off about fifteen minutes before the pump goes off to let it cool down. If you have electronic controls you should have one built into the system and will just have to activate it.
No promises but this could cause problems with time.
Oct 30, 2010 | Sta Rite 200k Btu Nat Gas Heater Maxetherm...
I have a elevated spa the overflows in to the pool when the pump is running but when i turn the pump off the water in the spa drops to pool level exposing the top stair in the spa. if i turn the nob on ...
Based on your description I'd suggest an electronic valve controller and panel to set the valve to the desired flow based on pump usage. If you do not have a control system with electronic valves you are likely in for some sticker shock but it would be the only way to automate what you are describing.
John
Oct 23, 2010 | Hayward Pool Products Hayward Power Flo LX...
I've lost the instructions to our skimmer or vacuum to the pool. How do I set it up or get an electronic version to show me how? Thank you.
I have lost the instructions to our vacuum to the pool. Do you have copies of manual's online to view. If not I need an electronic version to show me how.
Jul 02, 2010 | Intex "" Metal Frame Pool Set (56998e)...
How do I turn on the heat and the spa in the pool?
You must first make sure the filter pump is on and running (primed). If you have a pool spa combo, you will need to turn on the heater by making the desired temperature higher than the current temperature. This is a call for heat. You must then move the suction and return valves to **** and return to the spa. This is accomplished either by moving the valves manually or by putting it into spa mode if you have a control system. You didn't say whether or not you have a manual or automatic system.
May 18, 2010 | Hayward H Series Pool & Spa Heater...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
62 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
