Question about Genicom Tally T2250 Dot Matrix Printer
Hardware alarm +0322ne-007000 000000128 +0304
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
Hardware alarm 0036 131 000004 0376 0009 hardware alarm 0025 131 000004 0376 0009 hardware alarm 0024 131 000004 0376 0009
Hi, the printer seems to have a problem with the horizontal movement of the print head carriage. Turn of the printer and move the carriage by hand to check if there is an area where it can only be moved too hard. If yes, clean the carriage shaft from dirt, etc.
Sep 08, 2010 | TallyGenicom 2265+ Matrix Printer
Have a 1998 lincoln continental that has factory alarm. but i dont have a keypad. i would like 2 disarm it, it goes off for no reason.
if its an aftermarket alarm, which im sure it is, find the brain to the aftermarket alarm and unhook it. trace the brain back from the car alarm siren hardware. it shoud b mounted somewhere under the hood. theres not a lot of available space in the engine compartment. so you should easily find the siren hardware. trace the wiring back to the brain and disconnect it. it cant be factory alarm. factory alarm only goes off when u dont use keyless remote or key to unlock a locked door or trunk. factory alarm blows horn and blinks parking lights
May 26, 2010 | 1998 Lincoln Continental
Printer will not work
Hi, this beeping alarm signifies error in one the hardware components, i advice you power off, check and key or clip all the hardware components very well, most especially the memory stick.
I wish you best of luck.
Jan 04, 2010 | Canon BJC 4650 InkJet Printer
Hardware alarm will not go away
It seems to be a gear problem . may some gears are not in proper position. function selection gears are not in proper position.
May 14, 2009 | TallyGenicom 7265+ 900 CPS GENICOM ANSI...
Tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Dec 07, 2008 | Tally T2250 Matrix Printer
Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
Aug 26, 2008 | Tally Matrix T2280 Printer
Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
Jul 29, 2008 | Tally Serial Matrix T2155 Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
Genicom Tally T2250 Dot Matrix Printer Logo
26 people viewed this question
Top Genicom Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Genicom Office Equipment and Supply Expert? Answer questions, earn points and help others
