Zoostorm touchpad How do I deactivate the touchpad?
Activate/deactivate touchpad
FN or function key and the icon key that looks like a mouse or touch pad. That combination will activate and also deactivate this mouse or touch pad feature.
Hope this helps ya.
Nerd Tech Junkie - Will
Dec 04, 2016 | Computers & Internet
Uninstalling touchpad driver
No need to uninstall the drivers, just deactivate the touchpad. You can do so through the device manager or use an Fn-Fx key sequence if you laptop has one. If you have a touchpad icon on the task bar, right click it to see if it gives you the option to deactivate the touchpad.
Oct 17, 2013 | Samsung Computers & Internet
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
Synaptics ps/2 touchpad not working after i installed new gamer mouse
It is possible that the install of the gamer mouse deactivated the synaptics touchpad. you can click on the icon in the system tray of the touchpad, browse to settings. There you should find a place where it asks if you want the touchpad deactivate when another pointing device is connected. Deactivate the checkbox and you should have your touchpad back on.
Aug 07, 2012 | Gateway Computers & Internet
How to deactivate numeric keypad and how to activate touchpad
to activate/deactivate numlock press F11 to activate/deactivate touchpad press F10
Jul 02, 2011 | Samsung N150 (36725723009) Netbook
My numeric keypad is activated how to deactivate it and how to activate the touchpad
to deactivate/activate the numeric keypad just press the F11 and to activate/deactivate the touchpad just press F10..Hope it will help you
My laptop touchpad was not working
The touchpad can be deactivated. Try to hold the Fn key on your keyboard while you press F7 to activate it. There might also be a separate key to deactivate/activate touchpad.
Jun 16, 2011 | Acer Aspire 5732Z-4855 Notebook
ZOOSTORM 10 230 TOUCHPAD KEEPS MINIMIZING TEXT
give it a reboot!.
Still if it does not works,
Remove all the gestures and uninstlall the driver,
reboot again,
Install the driver,
It works !
Rate this article and comment to keep in touch.
Sep 22, 2010 | Sony VAIO vGN-NS235J/L Notebook PC
Deactive mousepad in DELL
  1. Open device manager
  2. Open touch pad
  3. Disable or enable option towards bottom
Jan 18, 2009 | Dell Inspiron 6400 Notebook
Using acer aspire 5920 and touchpad has stopped working since installing usb optical mouse
Press Fn + F7 at the same time to activate and deactivate the touchpad.
The Fn key, or function key, can be used to activate or deactivate a number of functions depending on what F-key it is pressed with.
Nov 23, 2008 | Acer Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
