Question about Huawei Ascend
How do i restore the hardware - Huawei Ascend
Cant move cursor
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 24, 2013 | HP Mini 1000 Netbook
How can i get rid of Dxerror 8876086C
Step 1:
Feb 22, 2013 | Logitech QuickCam Computers & Internet
Turn on error 00173 ,00301,00163
Feb 13, 2013 | IBM ThinkPad 600X Notebook
0x00000ba how can solve this error
Feb 12, 2013 | Computers & Internet
Does not turn on
Step 1:
Feb 06, 2013 | Sylvania G-Netbook
Asus netbook refuses to boot up
Feb 04, 2013 | ASUS Eee Pc R101d Atom N455 1.66ghz 1gb...
How to remove flow restrictor from restoration hardware spray jet showerhead
Here is a walkthrough: http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html but you can also just call a someone who specializes in water damage to ask if it is reparable. You can pay someone to do it for you. http://www.allcarerestorations.com/Water-Damage.html
Jan 13, 2013 | Home
Cannot perform system restore
since you said earlier it was working it seems some program has disabled the system restore feature. follow the steps below .
right click on my computer icon on desktop > select properties > system restore tab > uncheck "turn on system restore on all drives" if it is checked.
hope this solves your problem.
Aug 10, 2009 | Microsoft Windows XP Professional SP3 Full...
CD Rom
Do a system restore to a time previous to where you drive worked..
For xp .. start all - all programs - axcessories - system tools - system restore
for vista .. start - system tools - system restore
or start search,, type system restore and hit enter
scroll down until you see system restore " restore to a previous date) cliak on that..
In eighter case follow the onscreen instrustions to do the restore..
if that fails you may need to format the system with the cd's that cam with it. insert the disk and restart the system..follow all instructions. NB:: this will erase all data,, backup important files before doing this..
Mar 01, 2009 | Compaq Presario 700 470024-192 Notebook
After installing restore disk computer continuasly reboots after start up
there maybe a hardware fault, is this your own restore disc specific to your pc? have you changed any hardware in the pc before using the restore disc, if so the software will not recognise the serial numbers of the new hardware and cause a looping reboot.
Aug 31, 2008 | HP Computers & Internet
Huawei Ascend Logo
48 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Danny Kuhlmann
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
