Lavor superwash 160
Keep tripping every minutes when using.
I have a Hotpoint BWM129 washing machine and the Delay start and Superwash lights are flashing. Can anyone explain what fault code this is? The door locked light is also on.
Manual says to unplug maching from wall for at least 40 seconds to a minute. This will reset the unit. If that does not work you will need to call a service tech.
Jan 30, 2015 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
Lavor superwash 160 exploded diagrams
try e spares on the internet they may help
Jan 17, 2014 | Kitchen Ranges
My orange maintenance is on, it has been on for 3 days.
You can go to most Autozone, Advance, or Oreilys autoparts stores for a FREE scan. The onboard computer will identify most problems. Get the Code number and verbal suggestions from the clerk who scans your car.
This service will only take less than 10 minutes. You could buy the part and keep it with you during your return trip.
I hope my solution helps you.
Oct 04, 2012 | 2006 Honda CR-V
Where is the trip meter reset button on a Lexus ES350
Hi there:
  • Turn the "Engine Start Stop" switch OFF with the trip meter A reading shown.
  • While pressing the trip meter reset button, set the "Engine Start Stop" switch to the Ignition ON mode. Continue to press and hold the button until the trip meter displays 000000.
  • Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using FixYa, have a nice day.
    Aug 21, 2012 | Lexus ES 350 Cars & Trucks
    Lavor thermic 3/s
    remove the spark plug and see if the cylinder if full of gas if so replace the needle and seat in the carb
    Aug 09, 2012 | Garden
    My zanussi washer dryer keeps tripping the electrics
    check ground wire for tightness on plug in and on breaker box.
    Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
    Washing machine doesnt spin on superwash
    This can be fault on the memory of the program controller as none of the other programs are being executed. Please remove the panel and processor controller board. Check for moisture or connection issues. If not this can be confirmed only with a swap and a new one should not be bought unless this is confirmed.
    Oct 26, 2011 | Maytag Performa PAV2200
    Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
    hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
    Feb 28, 2011 | Kitchen Ranges
    The Reset button on cord keeps tripping, when turned on it works for a minute then trips again
    There's obviously there is a short or electrical overheating problems omewhere in the appliance that's causing the circuit breaker (Reset Button) to trip. Stop using the AC unit and have it checked by a professional.
    Feb 04, 2011 | Heating & Cooling
    Superwash button constant flashing
    I do not have a solution but also have the same issue. That is when putting on a cotton programme, the superwash light comes on at the end of the programme and I am unable to open the door as it remains locked. I then have to put it to a rinse or spin cycle as it does not seem to have spun the clothes at all.
    Jul 15, 2010 | Hoover H140E Front Load Washer
    Washing Machines Logo
    29 people viewed this question
    Top Washing Machines Experts
