Question about EuroTech Washing Machines
PUMP REPLACEMENT WATER LEAKS FROM UNDER THE WASHING MASHINE WHEN SPINNING THE LAST WASH.
  • EuroTech Master
  • 17,130 Answers
Possible that the hose link to the drain is loose, the drain pump is defective and leaking or the rubber door gasket is faulty. Please take a good view
Posted on May 02, 2013
  • 8 Answers
SOURCE: washing machine leaking
pump seals worn or possible obstruction - remove pump and check for wear and rep[lace .
Posted on Oct 25, 2007
  • 24 Answers
SOURCE: Maytag A512 Leaks out airgap when draining/spinning out
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
Posted on Oct 08, 2008
SOURCE: Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Posted on Nov 11, 2008
  • 1382 Answers
SOURCE: my washer leaks water
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Posted on Jul 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: hotpoint Aquarius+ WF740 washing mashine flashing F-05s
  • F05 - Pressure switch jammed on full
  • The pressure switch must be changed.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Posted on Sep 15, 2010
    Water leaking from the panel under the turn knob
    Water comes in the back, then goes via to solenoid valves to the back of the powder tray, it then is distributed through holes above each compartment, take out the powder tray (push down the blue bit at the back of the softener compartment) and check for cracks or even blockages, (water goes from tray down the back and through a short rubber hose straight into the drum.
    Feb 11, 2014 | Russell Hobbs RH1042 Frontload Washing...
    Water leaks (drips ) into tub after cycle/spin is complete
    You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
    If the washer leaks water when is filling only, check the following: 1.Fill hoses
    2.The water mixing valve
    3.Filling injector ( If your washer uses one )
    4.Filling spout
    If the washing machine leaks during the wash cycle, check the following:
    1.The pump
    2.The tub stem & seal
    3.Tub to pump hose
    4.The drain hose
    5.Tub (rusted holes)
    6.The drum support bolts
    If the washing machine leaks during the spin cycle, check the following:
    1.The drain hose
    2.The tub cover seal
    3.The pump
    4.The pump hoses
    5.The stem & seal
    Feb 10, 2008 | Maytag LAT2300 Top Load Washer
    My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
    Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
    E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
    However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
    1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
    2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
    3 Wait for the washer to run a short diagnostic test.
    4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
    Jul 30, 2011 | Washing Machines
    My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
    This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
    Hope this helps
    kcomp1863
    Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
    Hello my name is Kevin Singh and i had purchased one of your Bosch Front loading washing machines (model number: wfk2401) probably about 10 years ago i used it last on this last Sunday and it seems to not...
    Have you checked the pump and filter are clear? Remove kickplate plinth panel to expose pump. Drain off excess water via small black hose. Check the hoses are clear, particularly if it is connected under the sink, via a spigot connection. If the machine has good motor action, but not spinning effectively, it will more than likely be a drainage problem.
    Oct 19, 2010 | Bosch Washing Machines
    From time to time the mashine is not evacuate the water and the mashine will not start for a new load .I have to unscrew the filter,drain the water and then will wash. Is a problem with the pump? thank you...
    a front loader huh, usually there is an access panel at the bottom front held on with 2 screws. remove this panel and trhere should be a trap filter that is plugged up. remove filter and clean it out, than put it back. or the water pump is going bad try the filter first.
    Nov 07, 2009 | Whirlpool LHW0050PQ Front Load Washer
    My he3t washer when water goes in tub it leaks
    most liklet to be a split pipe under the mashine lay it onits side and look under it at all the pipes replace the loos or split one
    Oct 25, 2009 | Kenmore HE3T Washer
    Avanti W797: Tub won't spin or water does not empty.
    Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
    Nov 20, 2007 | Avanti Top Load Washer W797
    Washing mashine repair
    Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
    Sep 17, 2007 | Washing Machines
    Washing Machines Logo
    29 people viewed this question
    Top EuroTech Washing Machines Experts
    shaun taylor
    Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
