Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice Dispenser Doesn't work...
I have model#: GS6NBEXRL00 Whirlpool Side-Side Refrigerator. The ice dispenser does not work. It chirps so it is trying to no avail. The ice in the inside bucket is freezing together. We've noticed water in the tray under the ice dispenser...I don't think this is from water being dispensed for drinks. The water dispenser in the door works fine. I have removed the ice bucket inside the freezer and noticed that ice has formed on the underneath side of the bucket. I have cleaned it out with hot water and then dried it out thoroughly. The ice dispenser then works sporadically until it works not at all again. Any help/suggestions?
  • Emdad Khan
    Emdad Khan Aug 22, 2014
    want to get those all sentences in a past tense : Clean and polish counters, shelves, walls, furniture, or equipment in food service areas or other areas of restaurants and mop or vacuum floors. Clean up spilled food or drink or broken dishes and remove empty bottles and trash. Scrape and stack dirty dishes and carry dishes and other tableware to kitchens for cleaning. Maintain adequate supplies of items such as clean linens, silverware, glassware, dishes, or trays. Stock cabinets or serving areas with condiments and refill condiment containers. Locate items requested by customers. Carry food, dishes, trays, or silverware from kitchens or supply departments to serving counters. Serve ice water, coffee, rolls, or butter to patrons. Perform serving, cleaning, or stocking duties in establishments, such as cafeterias or dining rooms, to facilitate customer service. Wipe tables or seats with dampened cloths or replace dirty tablecloths. Fill beverage or ice dispensers. Set tables with clean linens, condiments, or other supplies. Serve food to customers when waiters or waitresses need assistance. Replenish supplies of food or equipment at steam tables or service bars. Garnish foods and position them on tables to make them visible and accessible. Carry trays from food counters to tables for cafeteria patrons. Slice and pit fruit used to garnish drinks. Carry linens to or from laundry areas. Mix and prepare flavors for mixed drinks. Run cash registers. Wash glasses or other serving equipment at bars. Stock refrigerating units with wines or bottled beer or replace empty beer kegs. Stock vending machines with food. My Email : [email protected]
  • 1,010 Answers
I would think this is the dispenser motor, or some bad connection
Posted on Mar 18, 2013
  • fxca Dec 26, 2014
    Not in this case...but always check to see if you have a child lock-out buttons on front display. Often forgotten, this would turn off both ice and water.
  • 291 Answers
Sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Posted on Sep 08, 2007
SOURCE:
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Ice dispenser not working on whirlpool side by side.
Andy_hall800, we're sorry to learn of your experience with the ice maker on your Refrigerator. We apologize, but we wouldn't be able to provide you with any technical assistance due to we aren't certified Technicians. We recommend service.
Oct 24, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Will not dispense
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.          http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
Oct 13, 2007 | Whirlpool GC5SHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
1,489 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
