Question about Daewoo DTQ-25S2FC 25" TV
Lines on screen
Hi, I turned the TV on today and all I heard was " noise " that you usually hear when you have a " snowy " picture. I looked up at the screen and there were 2 white lines, 1 horizontal and 1 vertical about 1/4" inch thick that formed a cross ( + ). I disconnected the digital cable box to make sure it had nothing to do with it. I turned the TV on and off manually and still have the problem. Hope you can be of some assistance....Mike
  • mcaringi Jan 23, 2008
    I was ready to trash the TV but plugged it in one more time for the hell of it after it sat unplugged for about 2 months.......it works fine now !!!...I know what I saw and trust me ...it was just 2 white lines( each about 1/4 inch thick ) one horizontal, one vertical in the center of the screen that formed a cross...they both extended to the edges of the screen...the rest of the screen was dark...oh well, it works now so guess I will have to wait till next time it does something goofy to ask for help again...thx
    Scholar:
  • 57 Answers
Can you take a picture of the screen and post it? It is not possible for both the horizontal and vertical stages to fail at the same time to produce a cross. A picture of the screen would help significantly.
Posted on Jan 22, 2008
SOURCE:
Snowey on scrreen
I've been repairing TV's for over 15 years and I would say either a bad Tcon's or main board issue. Theirs no need to replace capacitors these days, you can get the main board from $40-60.
Have you tried using different devices on the unit? If your getting a snowy picture on a satellite receiver, check with your provider for troubleshooting guide their unit. Or let me know the provider and I can lead in you right direction.
Thanks,
Jason
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Jun 09, 2016 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
Jun 14, 2012 | GE 31GT660 TV
HI, i Have a 42" lg3000 lcd tv when I switch the
Hello, I have exactly the same problem with the exact same TV, white screen for about 15 minutes and than image appears perfect as if nothing happened. I have asked an ebayer which sells TV parts and he suggested it could be a main board or tcon board. I am quiet hesitant to fix my tv, but if the tcon board would fix it, i'd go for it. Did You manage to solve the problem yet?
Mar 29, 2011 | LG Televison & Video
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
PS3 went from a "snowy" screen to a black screen. HELP PLEASE!!
hi..
Two or more things, first make sure you have your audio vidio cables correct
Yellow= Video
Red= Audio right
White Audio left
Also make sure that the tv matches the input your cables are connected into. I would make sure the restart the PS3 to make sure the video is good (after checking the tv input)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Humming noise & lines in picture
There is a faulty capacitor somewhere in the unit sending wrong voltage. The system will have to be tested with volt-meter or capacitor tester to determine faulty capacitor
Jul 03, 2009 | Televison & Video
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Daewoo DTQ-25S2FC 25" TV Logo
83 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
