Question about Linksys SD208 8-Port Ethernet Switch (SD208KIT)
All cables are connected and lights are flashing but no internet connection
Sytem LED is on rest is not but all cables are in.
  • 556 Answers
SOURCE: no internet connection
Review the following links -- note they depend on the modem equipment supplied by Verizon. There may be more possibilities -- research of their help/support website could find the appropriate option for you. These indicate there may be steps to configure their equipment as well as your router for this to work.
http://www.dslreports.com/faq/9265
OR
http://www.dslreports.com/faq/13600
Posted on Jan 02, 2008
mlake33
  • 427 Answers
SOURCE: Fast Flashing Light - no Internet connection
Well, i also had a wrt54g router.Generally that type of router is only for a networkwith one, two max wireless items. When the led light is flashing very fast, it means it is working very hard. You may need to get a stronger router such as the wrt300n which can handle up to about 10 items. By the way, netgear routers are generally stronger and longer lasting than linksys.
Posted on Mar 29, 2008
jagalbraith
  • 19 Answers
SOURCE: wireless router not connecting
Be sure that your Modem plugs into the WAN port on the router.
1. Unplug your cable/dsl modem power
2. Unplug your Router power
3. Plug in your modem power ... wait for it to come completely up.
4. Plug in your WRT54G Router and wait for it to come up.
Press the reset button on the back of the router for 45 seconds while it is powered on. This will do a factory reset. Wait for it to come up. Then unplug it. Wait 30 seconds and plug it back in. Let it come all the way up.
Plug a PC into one of the switch ports on the router.
Now do an ipconfig /release and ipconfig /refresh in the command prompt of your PC to get an IP address from your Router.
Now you should be able to ping 192.168.0.1 and you should be able to get into the the configuration utility by putting http://192.168.0.1 in a browser. The username should be blank and the password will most likely be admin (all lower case).
Be sure to lock down your wireless SSID so neighbors and people passing by are unable to connect to your access point and do bad things on your network.
Posted on Jun 11, 2008
SOURCE: WRT54gs doesn't work anymore. I'm unable to
There should be a reset button for the router, you will likely need a paperclip or other small item to push the button in. Disconnect power to the modem, push the button, and while holding it, repower the router. The router will come up vanilla as it was originally in the box. You will then have to reconfigure the router. I would uninstall the router software from your desktop and reload it, then link your security settings.
Posted on Oct 17, 2009
  • 1214 Answers
SOURCE: the power led keeps flashing. can connect
Try rebooting both you modem and the router.
Unplug the modem, removing all batteries if it has batteries. Unplug the router.
Replace batteries (if removed), and plug modem back in.
Wait a minute or so, then plug the router in.
That should fix it. If not, reply back.
Posted on Dec 17, 2009
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Back light sometimes works
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 10, 2012 | Acer Aspire As5250-0327 320gb - Perfect...
Why is the crisco sytem on my router going on and off
if your refering on the led lights its normal theres just an activity from the router and the device connected to it.
> but if your refering with the internet connection upgrade the driver of the router make sure its updated and secured.
Jan 20, 2011 | Linksys Wireless-G Broadband Router
Wht can the problem be when i can see my SSID,
If u cannot connect to the internet, 1st make sure the power LED is not flashing, if it is flashing then power off all your connection device: DSL modem, Router and computer. After that, power on each device in following order: DSL modem->Router->Computer.
Another that u can check is the cable connection. Since your computer can connect to router, then the rest to check is the DSL modem must be connected to the internet port on the router and coaxial port to the telephone line.
YBC (/\)
Oct 04, 2009 | Linksys Wireless-G WRT54G Router
Modem and computer are not communicating.
Are all your connections in the appropriate place? Did you press and hold the re-set button on your router for 40 seconds and wait until all the lights are green on your router?
Jun 27, 2017 | Computers & Internet
Lost connection between switch and hub - LED flashes every 5 secs
You say you have the same problem when you connect the cable directly from router to laptop, so it apparently is not a hub problem. That leaves the router and the cable. You're fortunate in having a working system on the other port. Why not try swapping pieces to see which is the failed piece? For example, what if you swap the ports for the cables? If it's a router problem, then the "bad" cable should work when in the other port. What if you swap cables? That would reveal a bad cable. Finally, swapping computers would show a computer configuration problem, such as the connection not being set to automatic.
Jan 23, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Automatically Resets itself every 15 seconds
Check the reset buton it may not put properly adjusted, so it may be put the evice abck to reset. if this is okay, try and put off the device disconnect all cables that link to it. put it on without connecting it, then see if it is rest it self, it it doesn't then plug the cable one by one. this should help. good luck
Jun 12, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Dropping Connection
All the LED except power should be flashing, that indicates traffic flow, power should be steady.
If all wired and wireless connections fail it is unlikely the router, more likely the cable/adsl modem that is dropping connection. Test by connecting a pc directly to the cable modem, watch for dropouts. If fails, contact your ISP service dept for line check and do a cable speed check from an online source.
Check also terms of service for the package you bought, many low end services restrict speeds below dialup if you go over your transfer limit. Multiple pcs playing online games use a lot of bandwidth. the speed restriction may put you below the threshhold for game server
Jun 08, 2008 | Belkin (F5D5231-4) Router
Feb 07, 2008 | Linksys WRT54G3G Wireless Router...
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Linksys SD208 8-Port Ethernet Switch (SD208KIT) Logo
26 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
