Question about Gestetner DSm745 Black and White Copier
The copy is light, who can i fix it - Gestetner DSm745 Black and White Copier
    Habit-Forming:
  • 103 Answers
Kindly check if there is enouh developer in the unit .if there is check the glass covering the laser unit and clean it.
if there there is no developer then change it and the problem is solved
Posted on Jun 06, 2014
I am unable to copy light or very light color in my Canon ir 2870.Gradation of shed are not available.How can I fix it.
Check OPC drum and charging roller.
Go to service mode and set develop
asterisk * button then press at a time 2 and 8 again press asterisk * button
select copier>adjust>develop
touch on develop increase the develop value 10, 20 as your satisfaction..
Jun 28, 2016 | Canon Office Equipment & Supplies
How can I get my scanner to copy light blue lines
Most scanners cannot copy light blue lines due to the lightwave color of the scanner lamp. This is inherit in the system and cannot be fixed. Some scanners use a lamp that can see blue, but then those don't always see light red.
Nov 03, 2015 | Office Equipment & Supplies
Fuser problems
Fuser not cause light copy.If fuser problem the fuser unit not fixing the toner to paper (not fixing image).Light copies :dirty optical parts,Organic Photo Conductor drum,charge roller or charge corona wires or charge corona grid dirty,transfer/separator corona wires dirty.
Aug 13, 2012 | Office Equipment & Supplies
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
I have problem in Sharp AR-M205,and i don't know how to fix, error code F5
F5 00 Content Copy lamp lighting error Detail Copy lamp does not light despite the output of lighting signal. Copy lamp lights without the output of lighting signal. Cause DC power supply defective Control PWB defective Copy lamp defective Improper connection of harness between PCU PWB, DC power supply unit and copy lamp unit Check and remedy Check copy lamp for lighting with SIM5-3. Check harnesses and connectors between PCU PWB, DC power supply and copy lamp unit
Jan 12, 2010 | Sharp AR-M205 Copier
Fix light copies on Sharp AR 5631
if you darken the copies with the contrast adjustment and it is still light then you need to replace the drum... if its still light then replace the scan lamp...
Dec 24, 2009 | Office Equipment & Supplies
The copy light won't stay to copy
That is often an un-fixable problem. However, sometimes a fully charged fresh set of batteries will handle. (Use high-quality rechargables, not disposable alkalines.) Also try power cycling the unit several times.
Sep 27, 2009 | HP CapShare 920 Handheld Scanner
Totally black transmissions
Copy lamp has blown, light should shine in where original is placed.... it isnt lighting the paper up, so reflection received is black hence black transmit/copy result
It is just a small specilised floro but would probally be more ecomomical to replace machine than to fix it.
Nov 19, 2007 | Brother Personal FAX-190
Gestetner DSm745 Black and White Copier Logo
20 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
