Question about Panasonic Lumix DMC-FZ20 Digital Camera
Starts runs stops
Whenever I move the mode wheel the camera goes crazy. It would not move into the mode I want it to go in, and usually stays in A or S mode. Can I do something myself, or does it need to be fixed by a professional?
  • Panasonic Master
  • 32,281 Answers
Try resetting the camera by removing the battery for 5mins, replace the battery and open the camera's Menu then scrool to the Date & Time setting to set the current date and time.
If the problem still exist then you need to take the camera to a digital camera repairer.
Posted on May 03, 2013
My 99 vw beetle idles and tries to die at a stop light but when driving it is fine? it kinda has me worried .
Not sure about the dying may be an oxygen sensor going out. The shaking may be your allignment needs fixing.
Jun 24, 2014 | 1999 Volkswagen Beetle
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
The zoom wheel does not stop when I want it to. It like it has its "own" will... Once I start zooming it goes all the way until the max. Sometimes when I make it (somehow... I don't know how)...
Hello.
It sounds like your camera's lens is broken. Did you accidentally drop it? When you shake your camera, do you hear something moving inside? Like a loose part? Or looking in the lens do see anything amiss?
Aug 13, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
Sony cybershot dsc-w120 lens goes crazy whenever I turn it on and tells me to turn it off.
The camera should go off automatically when faulty. attempt to explore teh functions on the camera is discover the unique experience beyond power shut down requests. When powered on, capture a snap shot immediately or else the camera takes charge to poweroff to save batteries. Also, attempt to power charge since the insufficeient battery does not allow the camera to stay on long.
Jan 29, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
How does the four wheel drive on my jeep work or lock in?
If you have a CJ or Cherokee, when you move the 4x4 lever, it engages the transfer case which then transmits power to the front as well as the rear wheels. For most (99%) of all four wheel use, you use the front position on the shifter one notch behind the two wheel drive setting. Use 4 low only for pulling vehicles out of mud etc and don't drive in that range. If it sticks in 4wd after disengaging it, usually backing up about twenty feet will help.
If you have a Grand Cherokee, the 4x4 usually is a quadratrack unit. That one stays engaged but only goes into 4wd mode when the rear wheels begin to slip. (by itself). Rules for using low are the same.
It is very important to run the exact same size and style tires on any 4x4. It is mandatory on quadratrack units. Use of odd sized tires can cause driveline damage.
There are variations on different year vehicles but the basics remain the same.
Sep 01, 2010 | Jeep Cherokee Cars & Trucks
Garmin goes from Auto Pause/Resume constantly when moving.
Depends on speed. If you are running low speed (less than 3MPH) precision of GPS combined with low speed makes device crazy.
For walking, running, or country biking in hot climbing, set auto stop off.
Apr 18, 2010 | Garmin Edge 305 GPS Receiver
When I go to stop the drivers side read wheel locks up and the vehicle starts to fishtail. After stopping the wheel unlocks but the ABS dash light stays on.
you probably got contamination on that wheels brake, the anti lock light will go on whenever the sensor reads a fault on any wheel, repair the problem and reset the abs and all should be well
Nov 14, 2009 | 1994 Jeep Grand Cherokee
Okay my sony laptop windows vista crashed . it turns on but then it goes to a blue screen , i can get it to safe mode & i tryed disabling stuff but it like wont restart either , it goes from a blue screen...
Boot into safe mode by tapping the F8 key on startup, once you're in safe mode, run the system restore tool (usually in start -> program files -> accessories -> system tools -> system restore) to a few days earlier and restore. After that, install an Anti-virus application, such as AVG Anti-Virus, and scan your computer to remove the problems.
Hope this help!
Robert W.
Jan 09, 2009 | Computers & Internet
Custom setting
This is a known (albeit uncommon) issue with F100's.  Is the wheel on the top left set to the timer setting? If not it may need to be repaired.
Sep 25, 2007 | Nikon F100 35mm SLR Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
44 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
