Question about Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter
GOGO TRAVELLE throttledoes not brake when it comes to a stop
Battries fully charged, turn key on and only beeps 5 times. Thats all.
hi Hal, that is a issue around based the brake or connectors to the brake or the micro-switch that is moved when you move the drive , freewheel lever.. ... firstly make sure the scooter is in drive mode and not free-wheel mode ., where the axle comes apart you will see a number of connectors , make sure they are a good fit ...
Update me please...
Regards
Rob
Oct 29, 2015 | Pride Mobility Products GoGo Ultra X...
Need a repair shop to fix my gogo elite
This is due to the controller shutting down. Make the brake leverin the on position
Oct 08, 2014 | Pride Mobility Products Go-Go Elite...
How do I get my gogo elite traveler plus hd to engage the brake when parked on an incline?
Hi Scott, the brake itself could be failing or the other issue could be the controller itself or simply a bad connection (hopefully), so check the connections from the brake to the controller
Regards
Rob
www.gewizrepairs.co.uk
Jul 29, 2014 | Pride Health & Beauty
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
Beep codes beeps
Contact a local DME dealer in your area or, on the internet. Give them your serial number for the GOGO to order a new solenoid brake. It is important to have your serial number when ordering to ensure you get the correct part.
Jun 07, 2014 | Pride Mobility Products GoGo Elite...
I have the same problem on a forever active scooter .5 beeps then stops is it the brake micro switch?
hi, it means that the brake is giving the incorrect resistance , this can be because of a faulty micro-switch or simply a bad connection to the controller so worth checking ..
Please note : i offer a free controller and brake testing , you only pay return postage ..
Regards
Rob
May 24, 2014 | Pride Mobility Products GoGo Elite...
Pride Gogo scooter breaks don't work when I come to a stop
hi, so would it be right to say you can still push it when you stop ?
The brake simply stops the scooter from moving , it does not slow you down, the motor does that.
Does the brake click when it comes to rest ?, if the scooter has not been used for sometime or kept out in the cold it can start to seize, so spray some WD40 or contact cleaner would be best in the slot around the brake area now remember you just lubricated the brake so don't go near hills or road until you used it and you're sure the brake is working again.
Regards
GeWiz.
Feb 21, 2013 | Health & Beauty
I canot pull the lever to disengage to a free wheel
Your brake my be locked up due to corrosion . Take scooter and tilt it up so you can see under it and take spraw lube and spray where the lever goes into the brake assy then work up down or back and forth and it should lossen up
Mar 02, 2010 | Health & Beauty
Beeps when in drive won't move
How many times does it beep or is it continuous? Should beep a few times (usually up to 9 times), then stop, then beep so many times again, then stop and so an and so forth. Most of the time this is caused by the scooter being in freewheel or THINKING its in freewheel which could be a faulty brake switch. Also, on the GoGo ultra, the battery contacts regularly cause this problem and have to be replaced. They should be splotlessly clean and shiny for the contact to be good.
Feb 15, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
