Question about Konica Minolta bizhub Office Equipment & Supplies
Bizhub beep codes
I have a KM Bizhub C451. After we relocated the copier (it was moved from one office to another), it does not start any more. The control panel lights up, but displaying nothing, it makes the start-up sequence, but after ~ 1 minute from powering up, it beeps 5 times 5 beeps, after which stays in this state. Pressing any key it beeps twice (one short, one long beep), the on-off switch from the control panel works, I mean it stops and returns the machine in the same non-responsive state. The local KM service said that we should ask them to relocate the machine, and now they cannot fix the problem....
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
  • 241 Answers
SOURCE: Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
Posted on Jun 09, 2010
Bizhub c451 with still blue light at start up
if you depress the utility button are all the touch windows there? are there missing ones?
Apr 13, 2017 | Konica Minolta Bizhub C451...
I have a KM bizhub c 451 black imaging unit that prints faintly. I have replaced the following parts, PC drum, PC charger and starter( developer), yet it is not printing solid black.
replace the black image unit as a whole you do not replace the units as individual parts. Where did you get the drum from? or the PC charger as they come as one and you don't replace the developer as it is located inside the unit!!!!!!
Mar 22, 2017 | Konica Minolta Bizhub C451 Copier Print...
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
Trouble code p.14 bizhub 451
skew issue have tech come out and registration
Mar 02, 2015 | Konica Minolta Bizhub C451...
P 21 ERROR SOLV THIS PROBLEMS
replace the black image unit and run registration procedure
Feb 23, 2015 | Konica Minolta Bizhub C451...
I have a bizhub C451 in the office but no operating manual: I can't remember how to: add email addresses to scan to and delete old email addresses from the address book
You can download the manuals free from the KM Website:
http://help.bt.konicaminolta.ca
Click on the "Knowledgebase" link.
Utility/Counter button
#1 Create One-Touch
from there make selections that apply (Address Book).
once in the area you can create, edit and delete the one-touches
Feb 08, 2010 | Konica Minolta bizhub C351 All-In-One...
Error code when copying... C6103 on Bizhub C451
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
