Question about Garden
Ryobi trimmer My Ryobi 720r has worked great for many years. Recently, the engine would bog down when I increased the throttle and then die. I changed the spark plug and it ran great. The next time I used it, it ran for about 5 minutes then died and I have not been able to get it started since. I am using fresh gas mixed with fresh 2 cycle oil. I have replaced the fuel supply line and the return line. It seems like there is a whole lot of fuel running into the carburetor. Even when the trimmer is just sitting and not being used the fuel keeps running out of the carburetor and onto the ground. Unless someone else has a better idea my next step will be to order a rebuild kit for the Walbro WT-340 carburetor.
  • 7,482 Answers
Hi Jay...
Here are a few things to check
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on May 03, 2013
5 Suggested Answers
  • 115 Answers
SOURCE: Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Posted on Jul 06, 2009
  • 8 Answers
SOURCE: ryobi BC 30 trimmer bogs down with throttle
some have to warm up, although there should be a gas/oil mix screw on the carb try adjusting it
Posted on May 12, 2009
#1 Taper
  • 1041 Answers
SOURCE: CS30 Ryobi trimmer dies when I press throttle!
Yes. You just need to do a simple carburetor cleaning. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen is in carb. is free of debris. Use a Den Tek Brush,(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
  • 6468 Answers
SOURCE: ADJUST AIR FUEL MIX ON A RYOBI C430 TRIMMER
open the muffler and clean the screen inside of it
Posted on Aug 11, 2012
Ryobi BP42
Could be mixture is too rich. also check if carburetor is flooding the engine.
Jul 02, 2016 | Ryobi Garden
The engine dies when you try to rev it
You have to adjust the H needle on the carburetor. Quarter turns, when adjusting the high, the H needle, you have to hold the trigger in, throttle high... if it bogs, turn the h a little at a time and depress the trigger slowly until u hear the sweet spot...very simple fix.
Sep 14, 2015 | Ryobi Garden
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
TrimmerPlus 720r Manual
Mine would start and run on the primer gas then die. Replaced the plugged fuel screen under the flapper valves on the single large screw cover of the carb. Runs well now
Aug 30, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
How do I remove the clutch rotor assembly on a ryobi 720r?
I have the same model, I inserted a large screwdriver on the inside to stop the rotor assembly from spinning, then I used a pipe wrench (but channel lock pliers would probably work better) and then w/o much effort, I easily turned the wrench counter clockwise to loosen.
May 01, 2010 | Ryobi Garden
How is the clutch rotor assembly removed from a ryobi 720r trimmer
on my 767r there are 4 cap head screws on a funnel shaped piece that connects the shaft to the engine. Once removed you'll have access to the clutch
Aug 21, 2009 | Ryobi Garden
Is the fuel mix on a ryobi gas trimmer 50-1 or 32-1 ?
My Ryobi 720r is 32-1 but just to be sure go to www.managemyhome.com and download your owners manual to be sure.
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Jul 05, 2009 | Garden
Ryobi BC 30 trimmer bogs down with throttle
May 07, 2009 | Ryobi Garden
Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Apr 25, 2009 | Ryobi Cultivator
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
