When I switch on Manually or in Auto, the low beam (outside lights) do not come on. High beam and fog lights work fine.
SOURCE: 1990 525i bmw headlights
Check the wiring in the lights it may be poor construction or mis care that has madr a wire become looseand only rarely turn on
SOURCE: high beams wont turn on.
First place to start is with headlight switch. I did have a case many years ago when both high beams were blown out at once, but this is rare. When you have the headlight switch out, jump power from te low beams to the high beam contacts. If high beams come on, replace switch.
Bill
SOURCE: LOW BEAM HEADLIGHTS DON'T WORK FUSES ARE GOOD AND
If you are handling the bulbs with your bare hands that is why your bulbs keep blowing out. use a washcloth to put the bulb in or rubber gloves, anything that will keep your hands from touching the bulb.
