Washing symbol keeps on flashing - Washing Machines
    President:
  • Washing Mach... Master
  • 662 Answers
Lock flashing?
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
If whirlpool press 'end of cycle' button for 3 seconds.
Posted on May 02, 2013
Testimonial: "It is a Bosch Exxcel 8 Vario Perfect. It just keeps washing and washing, no matter what cycle it is on. The timer says 1.00 and then it keeps changing the time, it is not overloaded and not too much washing powder either "
The lock symbol keeps flashing, and won't allow me start programme
Sadly when we do not know a MAKE we can not assist you with the problem, perhaps if you contact the Mfg's website and ask tech support they can .
Dec 21, 2016 | Washing Machines
I have a Mitsubishi magna 2001 model and I'm having computer problems the battery symbol keeps flashing and it keep stalling and won't idall properly
You need to have the Alternator tested, the battery symbol indicates the system voltage is low. The other problems are due to the low voltage.
Sep 18, 2012 | 2005 Mitsubishi Magna Wagon
Washing machine has stopped and a symbol of a key is flashing. Door will not open and no program will work
The key and flashing = child lock.
To get rid of this - turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Ive just moved into a flat with a servis 7kg 1500AA washing machine and i have no instructions for it. when i press the on button the yellow light above another symbol flashes and nothing happens. ive...
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
Sep 10, 2010 | Washing Machines
Unable to use washer due to key logo 'flashing'. Have checked the plug at bottom right of machine no blockage there.
Please try this
the key and flashing = child lock.
close washing machine door, turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Than You
Sep 08, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
My new washing machine (Samsung WF8602), has a permanent Red flashing light on. The symbol is of a lock with a key in the centre, the same as on computers, to verify secure websites. I have pressed the...
i got same model today, i rang samsung and they said it was a known fault that was under investigation by there engineers. they said it shoud be fixed with an upgrade but in the meen time it was nothing to worry about.. they said to keep checking there website for news on the upgrade then to call them back... i checked there website and cant find anything about it... ill give it a few weeks then ill ring them again...
Jul 05, 2009 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
