Question about Panasonic NN-H764 Microwave Oven
Panasonic genius 1200w
All of the touch pad buttons have suddenly stopped working except for the Stop/Reset button which will only beep when pressed. On disconnecting and reconnecting power, the display shows an arrow (triangle) under the word Sensor, and the number "11". When the Stop/Reset is pressed the display goes to a ":" only and will not then change further. No other keys have any effect. The microwave was working fine up until now. Any ideas?
  • junglep May 02, 2013
    My microwave is a Genius NN-S562WF (not as listed above). Does that make any difference?
    I have turned power off for lengthy periods and then back on - but it hasn't helped. Have checked the fuse and interlock switches but no luck there.
  • Panasonic Master
  • 9,085 Answers
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
Posted on May 03, 2013
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic microwave touchpad not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may instead have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs, which depends on the exact model, one of these:
NNS688BA NNS688BAS NNS688LA NNS688LAS NNS688WA NNS688WAS
Please feel free to contact me directly if you need more help.
Posted on Oct 08, 2008
nuwan chinth
  • 111 Answers
SOURCE: Stop working
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Posted on Jan 12, 2009
jessefuture
  • 10 Answers
SOURCE: My microwave is not working
This is a very serious problem safety first! A microwave oven is safe
As long as the door is closed but is deadly if allowed to operate with it open.
There are safety switches built into the oven that disengage the high powered
Microwaves when the door is opened. They are not operating properly or
The oven would shut off when the door was opened. Microwaves can cause
Severe burns, cataracts, pacemaker malfunctions and cancer. Also microwaves
Can damage the electronics that control the keypad , you microwave oven
Is not just malfunctioning it is a severe health risk and sould not be used.
Unplug it and it must be repaired or replaced if it is still under wannty
And you pay very little are nothing let them fix it otherwise replace it.
Posted on Feb 25, 2009
localwonder
  • 6784 Answers
SOURCE: buttons on number pad dont work , except one
HI, the key pad or, touch pad is defective. you will need to replace it asap if possible.
These key pads run about 130 dollars tops. contact Panasonic for this part.
Posted on Jun 21, 2009
erpaalai
  • 999 Answers
SOURCE: Our Panasonic Genius 1200w microwave stopped
It could be just the fuse and fixed for a couple bucks. Only way to know is open it up and check it. Eric
Posted on Sep 04, 2009
My Oster Microwave #OM1201EOVG beeps when plugged in and will not stop. Just beeps continually. Is it broke?
probably bad touch pad, the unit thinks your standing there pushing and holding down a button on the touch pad. Will need new touch pad or main PC board. Tough pad cheaper, more common, start there.
Oct 06, 2017 | Oster Microwave Ovens
My start button of microwave suddenly stopped working only its stop button works.What can I do?
You could have a defective door switch. Or, a bad membrane switch on the touch pad. Or, the ribbon cable (if so equipped) between the touch pad and circuit board might not be making connections on all of its wires.
Sep 14, 2016 | Microwave Ovens
How do I get the microwave to stop beeping.It"s beeping and locking the controls by itself.
The touch pad sounds like it is trying to tell you it has a stuck pad. The touch pad will need replacing.
Oct 01, 2014 | GE Microwave Ovens
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
My microwave touch pad does not work except the stop/reset button
You probably need to call the manufacturer. Sorry, no other ideas.
Feb 14, 2013 | Microwave Ovens
Panasonic microwave nn-sn668b.. after cleaning it earlier today i went to use it and it didnt work. the time reads 00:00 as if a loss of power had occured (but didn't). The only button that seems to...
If the clock is not set, nothing will work as the controls require the time to be working. Press Clear/stop twice and press clock, set time and press clock again.
Hope this helps.
Dec 23, 2010 | Microwave Ovens
Hello, I know it might seem dumb, but I just purchased a genius sensor 1300 w and I can't put the clock at the right time... (sorry about my english, I'm french in africa :) ) Anybody could help me ? ...
Plug the microwave into the power source and press stop/cancel. Just above the stop/cancel button is "clock"
Press that and adjust by using the timer buttons.
Hope that helps but just in case go to Panasonics web site to download a manual if you haven't got one.
Nov 21, 2010 | Panasonic NN-SN657SMicrowave Oven
Panasonic Microwave Genius 1200W stop working. I move a little bit electric cord and it went on again. Then I pressed one min quick reheating. It blinks and stop working. Any solution ?
Assuming that you mean the whole unit goes off as if you unplugged it then the problem sound like the incoming power//you say that if you moce the cable then it comes on untill you try to use it //replace the whole cable from plug into the machine
Dec 29, 2009 | Microwave Ovens
I got this microwave in my house, but its not working. all the buttons are not working accept stop/cancel button. please send me the sollution.
I have a similar microwave that I recently repaired. NN-9854 (bad capacitor). So your microwave functions but you cant stop it unless you unplug it, it ends its cycle, or you open the door? Does it beep when pressed? If not, you need a new control pad.
Dec 19, 2009 | Panasonic NN-T888S Convection/Microwave...
Our Panasonic Genius 1200w microwave stopped working all of a sudden. It's completely dead - even the front panel. Is it worth fixing?
Sep 03, 2009 | Panasonic NN-H504WF Microwave Oven
Panasonic NN-H764 Microwave Oven Logo
188 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
