Question about Electronics - Others
How do i charge battery
Where do I plug in the charger?
  • 239 Answers
Please check out back side of the car
Posted on May 02, 2013
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
Batteries won't charge, bought new batteries and they won't charge either
Moore well it looks like you have a charger problem. With a digital voltmeter plug the on-board charger into the wall then take the voltmeter and plug the two leads into the two outter plug holes of the charger port under the front of the joystick set the meter to 200 volts dc. with the charger plugged in you should read 26-30 volts if you don't get that you are reading just the current battery charge 20-24 volts. If you can try to find someone locally that has an offboard charger and borrow it for a few hours. Plug the offboard charger into the charger port under the front of the joystick and let it charge the new batteries. I would try to find someone with an extra charger you could buy or contact your local provider and have them get you an off board charger to charge your chair. Hope this helps you
Sep 23, 2010 | Jet 3 Ultra Power Chair
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller...
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Aug 26, 2010 | Pride Jazzy Select 6 Indoor Power...
Battery in Jeep Grand Cherokee dead this am and less than 1 year old. I have a Everstart 100 battery charger plugged in and on the car. How long does it take to charge the battery. The charger is plugged...
How many amps does this charger put out????
A small trickle charger will take forever to fully recharge a dead battery, you'll need to have a battery charger that can put out enough amps to properly charge a dead battery.To clarify, the chargers sold at Sears, the large square types on wheels are the best for charging dead batteries and they also have an amp meter telling you how much the battery is accepting. After you charge your battery, you should be around 12.5 volts to 12.7 volts. DO NOT OVER CHARGE!!!
Jan 18, 2010 | 2004 Jeep Grand Cherokee
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
