Question about Sharp AR-5316 Advanced Digital Imager Copier
H4 error code - Sharp AR-5316 Advanced Digital Imager Copier
    Problem Solver:
  • 16 Answers
A H4 error code relates to the fusing unit not reaching the desired temperature within the time limit. This could be a heat lamp or thermistor failure. I recommend calling a local service engineer to take a look.
Posted on May 09, 2013
Hi my dishwasher is showing h4/5/6, wht does this mean please?
Check this link here
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3714-beko-electronic-dishwasher-fault-codes
H4/5/6 pretty sure it means errors H4, H5, and H6 hope this helps
May 03, 2016 | Dishwashers
Gree air conditiones H4 error code
Not answer my question is what is the solution for wall mounted unit Model number 18cith1 has error H4 this error meaning here mention system protection.
Apr 30, 2014 | Heating & Cooling
Error code h4
The error code H4 is a fuser error code. The cause is one of the following fuser lamp, thermal fuse or the thermistor.
Jun 07, 2013 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
Error code:H4-00
That copier is kind a old. The H4-00 is a fusing error code. The problem is that the fuser is not heatting up right. Mostly it is that
the fusing lamp is broken or the thermal fuse is blown. It will not reset untill the problem is resoloved
Feb 16, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
44 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
