Question about Compaq Computers & Internet
System disabled - Compaq Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Reinstall windows, or Factory reset...
Posted on Jun 06, 2013
2009 GMC Sierra traction control light on
traction control light on . DTC'S - diagnostic trouble codes are stored in ABS control module pointing to the malfunction . Take to a qualified repair shop or to auto part store that can pull these code. DTC C0242 00: Engine Control Module (ECM) Indicated TCS Malfunction
DTC P0856: Traction Control Torque Request Circuit
The electronic brake control module (EBCM) and the engine control module (ECM) simultaneously control the traction control. The EBCM sends a serial data message to the ECM requesting torque reduction. When certain ECM DTCs are set, the ECM will not be able to perform the torque reduction for traction control. A serial data message is sent to the EBCM indicating that traction control is not allowed.
DTC C0561 4B: System Disabled Information Stored Calibration Not Learned
DTC C0561 54: System Disabled Information Stored Temparature High
DTC C0561 59: System Disabled Information Stored Component Protection Time Out
DTC C0561 71: System Disabled Information Stored Invalid Serial Data Received
DTC C0561 72: System Disabled Information Stored Alive Counter Incorrect
DTC C0561 74: System Disabled Information Stored Value of Signal Protection Calculation Incorrect
DTC C0561 75: System Disabled Information Stored Signal Above Allowable Range
Traction Control Off Indicator
The IPC illuminates the traction off indicator when the following occurs.
• The EBCM disables engine torque reduction due to a malfunction and sends a serial data message to the IPC requesting illumination.
• The driver manually disables VSES and engine torque reduction by pressing the traction control switch. The EBCM sends a serial data message to the IPC requesting illumination.
Sep 04, 2017 | GMC Cars & Trucks
Is there a fuse that enables or disables the anti theft system?
didnt specify vehicle some actually have fuses others auto breaker but when fuse blows system will be disabled but it will also disable vehicle until fuse replaced --so pulling a fuse to disable your security system because of a problem will also disable your vehicle
Jun 11, 2017 | Cars & Trucks
Just bought 2003 Aztec and the AWD is disabled how do i know if something is wrong . We could not find AWD button ? ??
AWD Disable indicator
The AWD Disable indicator is located in the instrument panel cluster. This lamp is used to inform the driver that the AWD system has been disabled and no torque will be applied to the rear wheels during a slip condition. The AWD Disable indicator is controlled by the powertrain control module via a class 2 message.
Powertrain Control Module
The powertrain control module monitors the data from the ABS controller and Rear Drive Module (RDM) for proper operating conditions. If inappropriate conditions are present the PCM commands the differential clutch pump actuator check valve closed, disabling the AWD system. The PCM also commands the AWD Disable indicator on.
Is the All-Wheel Drive Disabled Indicator Always On ?
Is
Oct 25, 2016 | Cars & Trucks
How do I permanently disable the traction control on my 2012 Toyota Tacoma?
The system is integrated with several other systems. They are all connected and talking with each other. It is almost impossible to disable one without disabling or inhibiting one or more of the other systems.
Why do you want to permanently disable it?
Sep 27, 2014 | Cars & Trucks
How can I reset my system password?
Disabling a Forgotten Password
If you forget the system password, you will be unable to operate the system until disabling the password. Disabling the password involves going inside the computer and changing a jumper setting (twice) on the system board.
To disable a forgotten password, perform the following steps:
  1. Turn off the system and remove the cover.
  2. Move the jumper plug on jumper A to pins 2 and 3 to disable the password(s).
  3. Turn on the computer. Powering up the system with jumper A set to the disabled position erases existing password(s). Before assigning a new system password, you must reset jumper A to the enabled position.
  4. Turn off the computer.
  5. Place a jumper plug on pins 1 and 2 of jumper A to enable the password features.
  6. Replace the computer cover.
Dec 28, 2012 | Dell Latitude E4300 Notebook
I do not wish to disable my sound system entirely
go to keyboard and mouse option from control panel, from settings you can disabled popping sound.
Apr 12, 2010 | Microsoft Windows Vista Home Basic for PC
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
HOW TO DISABLE PYTHON ALARM SYSTEM WITHOUT DISABLE DOORS LOCKS
This is not to hard but easier to answer if i know why you want to do this as if for example a certain feature of the alarm is playing up i suggest we just disable that feature ,its easier.
Apr 04, 2009 | 426P 460HP Security System - 426P
How to disable Cd drive windows xp in a local user
you can disable the CD drive and USB in the BIOS or go to
regedit:
Hkey_Local_machine\system\CurrentControlSet\dervices\cdrom\start
1=eable, 0=disable
hkey_local_machine\system\CurrentControlSet\devices\usbstor\start
3=enable, 4=disable
Mar 09, 2009 | Microsoft Windows XP Professional
System restore
Start the System Control Panel applet. Select the System Restore tab. Clear the "Turn off System Restore on all drives" check box to enable System Restore, or select this check box to disable System Restore. Click OK.
An alternative to the usual method of enabling and disabling Windows XP's System Restore feature is to use the registry. To use this alternative, perform the following steps: Start the registry editor (regedit.exe).
Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore.
If a "DisableSR" value doesn't exist, go to the Edit menu, select New, DWORD value, and create the value.
Set the value to 1 to disable System Restore or 0 to enable System Restore.
Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\sr to prevent the System Restore service from starting.
Double-click Start, and set the value to 4 to stop the service from starting or to 0 for normal startup. Close the registry editor.
Feb 07, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
