Question about Sharp IS05 unlocked Japanese Gsm Phone
Codes how to remove the passcode
    New Friend:
HI how are you i have a IS05 hOW CAN WE HARD RESET
Posted on Mar 03, 2014
My son has put a passcode on my iPad how d I remove it cz dnt know passcode
Interesting question, I looed it up because my memory is so bad I'm likely to forget mine! I only pass coded it to keep the grandkids off it!
See link for instructions from Apple iOS Forgotten passcode or device disabled after entering wrong passcode
Sep 12, 2014 | Tablets & eReaders
How to remove passcode
Do you want remove your mobile network lock passcode? Yes means you can visit this site Superunlockcodes.com here you can get the network unlock passcode and remove your mobile network lock pass code easily. To get the code you have to mentioned your mobile brand name,model,which country is locked now,network provider and imei number. Then they send network unlock pass code through email.
Sep 06, 2014 | Cell Phones
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
How do I remove pass code
Settings>Passcode>Turn Passcode Off
Jul 29, 2014 | Apple Iphone 4s I Phone 4 S Factory...
How can i remove password of iphone 1387 codes
Settings - Touch ID & Passcode (for iOS 7.1)
for other versions I think: Settings - General - Passcode
Apr 14, 2014 | Apple Iphone A1387
Need passcode for xdvd8183 i put it in it came on and said enter passcode
The radio SERIAL NUMBER is required for a code First remove theradio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
May 17, 2011 | Car Audio & Video
Dont rem passcode
If you don't remember the passcode to your iPod, simply enter any code 5 times and it will reset the device. Then plug it into your computer and reinitialize the device.
This will remove the passcode.
Mar 05, 2011 | Apple iPod touch
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    I am trying to pair my lg Xenon with my Lenovo laptop. Both devices ask for the passcode.. I don't know the passcode is what should I enter?
    For initial pairing, you're the one to provide a passcode. So if the system asks you to enter passcode, you will need to enter a code that you will use as this is the enrollment process. Once the passcode went through, the paired devices will be connected and locked to the system unless deleted or removed manually, so make sure to use a generic passcode that you can easily remember so you won't have any problems in the future. Hope this helps!
    May 19, 2010 | Trendware TRENDnet TBW-101UB Bluetooth...
    What is the passcode of nokia n95 8gb? When i transfer a song from nokia6300 to nokia n95 8gb through bluetooth it is not working, in n95 8gb it is asking the passcode of nokia 6300? How to solve this...
    type the pascode that you typed in 6300 for transmit data..if passcode is not given type 12345..it will work....if you want to remove this, you just paired 6300 to your n95. Then it wont ask for passcode..Hope this will help you...Thank you...
    Oct 27, 2009 | Nokia N95 Cellular Phone
    Sharp IS05 unlocked Japanese Gsm Phone Logo
    106 people viewed this question
    Top Sharp Cell Phones Experts
    Starnley Johnwells
    Starnley Johnwells
    Daniel Dollive
    Daniel Dollive
    ismael castillo
    Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
