Question about NEC Socket 5 Motherboard 00A (1580261741)
Bios error code
When i switch on displays "the following informatiom programed intothe system board is missing or invalid"
    Brigadier General:
  • NEC Master
  • 3,400 Answers
USE YOUR WARRANTY
Posted on May 02, 2013
What are the dell beep codes for dell inspiron m5010
Table 3-1. POST Beep Codes
Beep CodesErrorProbable Causes
1Memory refresh failure.Defective system board.
2Error occurred in first 64 KB of main memory.Faulty DIMM or defective system board.
3Read or write error occurred in first 64 KB of main memory.Faulty DIMM.
4Timer on system board malfunctioned.Defective system board.
5Microprocessor error.Defective microprocesor.
6Gate A20 failure.Defective system board.
7Microprocessor-execption interrupt error.Defective microprocessor.
8Video memory read/write error.Missing or faulty video adapter.
9ROM checksum value does not match value encoded in system BIOS.Corrupted system BIOS program or defective system BIOS chip.
10NVRAM shutdown register read/write error.Defective system board.
11Cache memory error.Defective microprocessor or cache card.
1-2Video adapter failure.Faulty video adapter.
1-3No monitor connected.Loose video cable connection or defective video cable.
Jun 17, 2014 | Dell Inspiron 15 Laptop Computer- Intel...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
Loose video cable connection or defective video cable.Faulty video adapter.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
Invalid System Board
Open the BIOS, is the time correct? Consider replacing the CMOS battery. You didn't mention the Make , Model of computer or the OS.
Jan 04, 2013 | Computers & Internet
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
At POST I get 2 short beeps
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly
Short continuous beeps: Bad power supply
AMI BIOS:
1 short beep: DRAM flash error
2 short beeps: DRAM ECC check error
3 short beeps: DRAM detect error
5 short beeps: CPU error
6 short beeps: Keyboard error
8 short beeps: Video card error
1 long and 3 short beeps: Bad DRAM
1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
BIOS Beep Codes
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
AMI BIOS
# of Beeps Error Description
1 Refresh Failure The memory refresh Circuitry is faulty
2 Parity Error Parity error in the Base (1st 64K) of memory
3 64K Base Memory Error Memory error in the base memory (1st 64K)
4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
5 Processor Error CPU error
6 8042 Gate A20 Failure Unable to switch to protected mode
7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
9 ROM checksum error The ROM checksum does not match that of the BIOS
10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
IBM BIOS
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error
1 Short Beep Normal POST, System booted OK
2 Short Beeps POST Error - Code on Display
No Beep Power supply or Motherboard error
Continuous Beep Power supply or Motherboard error
Repeating short beeps Power supply or Motherboard error
1 short, 1 long beep System board error
1 long, 2 short beeps Display adapter error (MDA/CGA)
1 long, 3 short beeps Display adapter error (EGA/VGA)
3 long beeps 3270 keyboard card
Phoenix BIOS
The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
1801 microcode patch erro
These are very different CPU's, and you should make sure the board accepts the new one. Check the manual.
Oct 26, 2008 | Compaq Evo D500 PC Desktop
ya'll need to flash (upgrade) your motherboard BIOS to allow it to be compatible with the new CPU's.
Sep 17, 2008 | Computers & Internet
NEC Socket 5 Motherboard 00A (1580261741) Logo
20 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
