Question about Refrigerators
Freezer full of ice but products not frozen
I have a confusing issue with my freezer. I have ice build up on the back wall of the freezer, and sometime pools of ice on the shelf as if the unit has defrosted and refrozen. However, products are not frozen, especially in the front edge or in the door. Any suggestions? I've tried changing the temperature, and checking the door is closed.
  • Helen McClure May 06, 2013
    The issue is now fixed. To give some feedback, the temperature controller had become dislodged so ice built up on the fan.
    Top Expert:
  • Refrigerators Master
  • 12,173 Answers
Ur evaporator fan either frozen and or burnt out listen and or if able to put a meter on to test--- if need to replace u will need to let defrost enough to rmove the rear panel---- unplug unit--- and unbolt fan disconnect wire connection and replace with a new one
Posted on May 02, 2013
  • 29 Answers
SOURCE: Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Posted on Aug 13, 2008
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
Kenmore model 795.71022.010 water builds up in the bottom of the freezer every two weeks I have to defrost the unit and remove the ice build up if I dont the door wont close
The fan unit behind the wall inside the freezer may have frozen over.
Even though you see no ice inside the shell of the freezer, it can still have blocks of ice behind the back wall.
So remove the 3-4 screws holding the back wall, remove it and check on the ice there.
Make sure it is completely defrosted or ice melted before reconnecting. Leave the wall off while you connect it to make sure the small fan is kicking in.
IF the fan does not kick in. you can get a replacement for $15-$20 at any fridge parts supply house. It is easy to disconnect and reconnect.
Jun 04, 2016 | Kenmore Refrigerators
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
Oct 12, 2013 | Refrigerators
I have a 3.3 fridge/freezer-the back wall of the fridge has a buildup of ice ???
Sounds like either: 1) The thermostat is set too low.
2) The defrost control is bad
3) The main drain in the freezer has frozen over not allowing water to drain.
Jan 29, 2013 | Haier HNDE03VS 3.3 Cu. Ft. 2 Door...
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Freezer Does Not Stay Frozen
one of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Feb 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Freezer doesn't keep ice cream frozen
not being able to keep ice cream is not good, before doing anything ck a few things. make sur e to pull out unit and vaccuum under and behind unit, if it cant breath it cant freeze. check in back by compressor, is the fan running to cool the fan??? if the compressor is on so should the fan be. next id look behind the freezer wall for excessive build up of frost( it might even be buildin up with ice throughthte back wall, inwhich case you have a defrost issue
Apr 02, 2008 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
