Projector Problem Pixels error at the button corner of the screen from the projector
    New Friend:
  • 3 Answers
Does the same thing happen with other inputs?
Posted on May 31, 2013
projdoc
  • 2237 Answers
SOURCE: XV-H37U projector. Red power light is on when
reset the lamp timer. it's usually hold menu button , down arrow, and enter, and press power. but it's an old projector and may be different.
Posted on Nov 30, 2009
dhiman
  • 115 Answers
SOURCE: Hitachi LCD Projector
Hello Dear,
This problem seems to be the main card problm which is connected with the RGB Panels of the Projector.
Viren
Posted on Nov 27, 2007
SOURCE: Projector shows only 50% of the computer screen
mine does the same thing but i can see the whole screen it's just half height full width, above solution about zooming to 1X is what i've been doing to fix it for the last 6 months, needs to be done every time I turn the power back on. Anybody know of a more perminate fix?
Now my power supply has gone have the projector in pieces, found a failed on transistor but because it's over heated can't read of it what type it was....
Already replaced two blown diodes in the main H-bridge
Looks like one coil will need rewinding.
If anybody has one in pieces I would be great if you can help me work out what the blown transistor was.
Posted on Mar 25, 2008
  • 12 Answers
SOURCE: Multimedia projector display too pink
check the vga cable, usualy its a broken wire inside
Posted on May 18, 2009
projdoc
  • 2237 Answers
SOURCE: projector buttons locked
unfortunately, you need the remote. fortunately, you can use almost any sharp projector remote (same code). when you do get one, press (in this order)- menu, enter, enter, menu, undo, undo, menu.
Posted on Jul 20, 2009
There are white dots on the screen of my dell 1210s Projector
Dell projectors are known for using extremely cheap display chips... Most probably the pixels are stuck you will have to send it to dell for service
Oct 28, 2014 | Dell 1210S Projector
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
White pixels nec np100
Your DLP chip is damage or getting to been damage.
** To make it sure you can do it your self by getting some basic tools such as proper screw drive, and open your projector for parts.
And you can physically observe the Chip.
Please check by side angle on the chip surface. **
Feb 14, 2014 | Optoma DLP Projector Multimedia Projector
White dots on the screen
Need more info. But initial suspicion is there is a problem with your projector.
Are they stationary and always in the same position? You may have bad pixels.
Are the dots there with no signal going to the projector?
What is connected the the projector? Detail the video path - try all the sources. The dots still there and in the same position on all sources?
It is probably your projector.
If some of your sources are fine - the problem might be from a connected source.
Hope this helps.
Aug 26, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
When I turn the projector on I get scattered bright white pixels showing up on the screen with no color. What causes this.
Hello!
Bad news: the problem is the light engine! most expensive part of the projector. Due to high temperature inside and extended usage with poor ventilation, plastic filters inside the light engine start melting and picture gets "spotty". Next, the color matrix quits and one of primary colors is missing. In any case, light engine is "goner". It's very big job to replace it. I would surrender to repair facility in your place. Or, if you can get replacement projector for a good price, just do that. Your projectors repair bill might be $500+,or more. due to high cost of light engine.
Good luck,
thanks,
Alex.
Dec 21, 2011 | Panasonic ET-LAC735 Multimedia Projector
Hitachi CPS-220 is saying 'RGB is out of range' when connected to PC.
This would indicate that the display settings on the PC are outwith the acceptable range of the projector.
To solve this, right-click on a clear part of your PC desktop and select "Graphics Properties" (in Vista). You then need to adjust the display settings. That is a very old projector which will accept a maximum screen resolution of 1024 x768 pixels. Try changing that 1st. If it doesn't work, keep that screen resolution and also adjust the refresh rate in Hz until you get an image.
The native resolution of that projector is SVGA (800 x 600 pixels).
Feb 14, 2011 | Hitachi CP-S240 Multimedia Projector
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
Screen adjustment
Adjust the screen area of the computer’s display settings to match the projector’s native resolution. Refer to your projector documentation for the optimum or native-resolution setting for your projector model. If you can't find this information or are uncertain, most projectors support a maximum of 800 x 600 pixels.
• With certain laptops, you might need to disable the laptop display to obtain the best image, especially when the native resolution of the laptop exceeds the native resolution of the projector.
• Font smoothing will automatically generate a cleaner font outline, both on your laptop and on the projector. To apply font smoothing, do the following:
1.
In Control Panel, open Display.
2.
On the Appearance tab, click the Effects button.
3.
In the Effects dialog box, select the Use the following method to smooth edges of screen fonts check box, and then select Standard or ClearType in the list.
If the projected image is dimmer than it was on the laptop, check your projector documentation for information regarding lamp timers. If the lamp life has expired, replace the lamp for maximum brightness.
If the projected image is not rectangular, try one or both of the following:
• Make sure that the projector is perpendicular to the viewing screen.
• Raise or lower the projector.
If the projected image displays vertical lines, "bleeding," or spots, try one or more of the following:
• Adjust the brightness of the image.
• Check the projector lens to see whether it needs cleaning.
• Adjust the sync and tracking on the projector.
Sep 09, 2008 | Panasonic Videoprojector PT-LM1E...
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
1,361 people viewed this question
k24674
jasbo
jasbo
