May copier ir 3100cn show error code E000020-0081 how to solve it
Error E000020-0018
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 47 Answers
SOURCE: canon ir-c3100 copier error code
The ITB or Intermediat Transfer Belt is slipping or not being driven properly. It is NOT fun to take out, particularly if you have a finisher attached. If you have proffessional experience with copiers and are really determined, let me know and I may be able to set you up with a manual. Otherwise, call a pro.
Posted on Jul 26, 2008
SOURCE: Canon iR 3100CN copier
its hard drive problem so change it
Posted on Sep 10, 2008
hi how do solve this problem system error E007
Posted on Apr 09, 2009
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Problem :
E604 Error Code. You followed all the troubleshooting steps in the service manual and still have an E604 code.
Solution :
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity.
Jul 13, 2012 | Canon imageRUNNER 400S Copier
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Canon iR 3100CN Error code E000732-0001
E732 Reader communication error
0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the
reader power supply
Hope that helped!
Jul 25, 2010 | Canon iRC3100 Printer
Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Jun 06, 2010 | Canon iRC3100 Printer
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Showing error code E000020-01a9 on IR 3100CN
this code is for the density of the yellow toner, most likley has a bad drum.
Aug 13, 2009 | Canon Office Equipment & Supplies
Aug 18, 2008 | Canon imageRUNNER C3200 Color Printer
21 people viewed this question
k24674
jasbo
jasbo
