Question about Garden
How do i set the timing on a toro lx 425 twin cam
SOURCE: SET TIMING ON 2.4 TWIN CAM 1999 MALIBU
bring the piston no 1 on the top position check the cam shaft si moving freelyon the outer side of the shaft there are 2 gear with 14mm bolts and 1 extra whole, put a long bolt in the empty space and try to turnthe engine the bolt will go further in the space than the timming is set put the chain on that should do
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: 2007 Toro LX 425 Riding Mower, slow cranking.
check the starter see if it is going bad or not?
Posted on Apr 18, 2009
jagjeffery
  • 318 Answers
SOURCE: Peter
this is for the 8 valve graphic.aspx?mod=reptiff&module_id=1&session_id=%7b909888e5-fe6a-4938-9e0c-31cb776f66af%7d&image_guid=90c00275&print_bw=0& engine
Posted on May 29, 2009
pippall
  • 1486 Answers
SOURCE: Toro LX 425 Backfires when shuting down.
pree ingnition problem.This happens when you get carbon build up in the cylinders on top of pistons.it keeps burning when you turn off the ignition igniting the fuel when the exhaust valve is open.Use a good additive to clean the carbon away And take it for a long run.That should solve it.
Posted on Jul 06, 2009
  • 257 Answers
SOURCE: I own a toro lx 425 lawn tractor, now it wont go
you can check the idle pully to see if it is working,, spring could be stretched,,or you could need new belt, hope this help
Posted on Aug 30, 2009
My toro lx 420 wants to stall when engaging the blade sometimes..also when I push on the reverse, it acts like to wants to stall as well...any easy troubleshooting ideas? runs fine when not engaged
Try rolling when you engage instead of in the still position may be too much on the motor, either that the belt is loose or needs to be replace. Or u need a carb adjustment at the idle.
May 02, 2016 | Toro Riding Mower LX Series 22 HP Kohler...
Set timing of crank and cam shafts on a Kohler K161 engine
Since there different versions with and without gears it is best to read and following the instruction in the service manual.
Kohler K91 141 161 181 241 301 321 341 Service Manual pdf Google Drive
Oct 25, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Where is the fuse box on the toro lx 425 lawn tractor
MOST LAWN TRACTORS DO NOT HAVE A FUSE BOX. SEE IF THERE MAY BE A IN-LINE FUSE.
May 26, 2012 | Toro Garden
Hydro pump reserve blowing out fluid on Toro z- master
is this all after the parts where changed and while bleeding out the air put the system under vacuum
May 13, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Will not reach top hp exhaust cherry red
Your carb is in a lean codition which causes the exhaust to glow. I would recommend having repair shop rebuild carb .This way you get it set properly and should have to make only minor adjusments .I also recommened running a fuel stabilizer all the time .
Feb 04, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I own a toro lx 425 lawn tractor, now it wont go forward nor reverse. The belt is not broken, possibly stretched. Can I adjust the belt to fit again? If so, how do I go about that?
Aug 26, 2009 | Garden
Apr 18, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
